Oil Drain Plug - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 02-16-2011, 08:56 AM Thread Starter
Someguy's Avatar
Oil Drain Plug
As I am not Close to my XX I was wondering if anyone can help me out. Does anyone Know the size of the oil drain plug.. Not the wrench you put on it but the actual size and thread pitch.
DWT Red label Wheels
Razer II tires
Fox Float Evol X Front Shocks
Fox Podium X Rears
Pro Armor Nerfs
Trail tech Bar clamps
Flexx Handle bars
Barker Exhaust
EHS Lid
EHS Programmer
Acerbis Uniko Handguards
2011 Can Am Commander 1000X
Someguy is offline
post #2 of 15 Old 02-16-2011, 10:43 AM
92K1500's Avatar
I'm not positive but I THINK it's a M12 x 1.75.
Why do you need to know?
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #3 of 15 Old 02-16-2011, 11:03 AM Thread Starter
Someguy's Avatar
Thanks 92k1500
Trying to make a better way to Drain the oil with the Skids on.. I have time to think and research what would needed as long as I can get the right sizes
Razer II tires
Fox Podium X Rears
Pro Armor Nerfs
Flexx Handle bars
Barker Exhaust
EHS Lid
EHS Programmer
Someguy is offline
post #4 of 15 Old 02-16-2011, 11:22 AM
92K1500's Avatar
Next time I change my oil (probably a month or so as I just changed it) I can get you the exact measurement if someone else hasn't gotten it by then and you still need it.
2008 Honda TRX700XX
92K1500 is offline
post #5 of 15 Old 02-16-2011, 11:46 AM
Thinking of the Fumoto valve or the Fram Sur-drain?
2006 Raptor 700
post #6 of 15 Old 02-16-2011, 12:12 PM
Someguy,
I looked at both those drain valves. They are both built with quality in mind. I do have two concerns.
1- After draining the oil reservoir you still have to drain the bottom of the engine.
2- If not positioned in a protected area, a stick or other debris could activate the ball valve handle.
Just a thought.
post #7 of 15 Old 02-16-2011, 12:17 PM Thread Starter
Someguy's Avatar
Actually was Looking Into Aeroquip for the Drain. It has a cap that goes on to Protect it, this is just an Idea as I cant actually see my XX.. I will be stateside in about a month and am looking at doing full service as well as install of my UHMW Skids. Figured look into this prior to Skid install while Oil is Drained.
Razer II tires
Fox Podium X Rears
Pro Armor Nerfs
Flexx Handle bars
Barker Exhaust
EHS Lid
EHS Programmer
Someguy is offline
post #8 of 15 Old 02-16-2011, 12:51 PM Thread Starter
Someguy's Avatar
Thank you I would appreciate it, I have found all the parts I would need for the M12x1.75 I will hold off any ordering until I hear for sure from someone. I will be Going with Aeroquip as it does come with an Aluminum Cap to Protect the connection.
Razer II tires
Fox Podium X Rears
Pro Armor Nerfs
Flexx Handle bars
Barker Exhaust
EHS Lid
EHS Programmer
Someguy is offline
post #9 of 15 Old 02-16-2011, 12:56 PM
How much do these valves protrude? On my previous raptor I installed the Sur-drain, it has a brass cap to protect the valve and protrudes about 3/4" so it was well protected by my aluminum belly skid.
2006 Raptor 700
post #10 of 15 Old 02-16-2011, 12:57 PM
Oh, also on the Fumoto you can get a security clip to make sure the drain handle cannot be tripped. Also these do not protrude into the engine much so practically all of the oil will be drained.
2006 Raptor 700
