13t vs 14t - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 02-17-2011, 10:43 AM Thread Starter
holy700xx's Avatar
13t vs 14t
Anyone that was running the 13t switch back to the 14t after the big 3 or keep the 13t?
holy700xx is offline
post #2 of 14 Old 02-17-2011, 12:14 PM
Talked to Eric from EHS about that the other day. He was saying you wouldn't want the 13t with the added power, would make 1st gear useless.
manchvegas is offline
post #3 of 14 Old 02-17-2011, 12:19 PM
Stevem12065's Avatar
I put the 13t on before I got the big 3 and have yet to go back to the 14t. I do like te 13 for the more technical rides it makes it a lot easier to crawl over boulders trees and such. If Im racing someone I usually start in 2nd gear. In first youll just spin til you shift to 2nd
2008 Black on Black 700XX
Pro Armor Fat Peg Nerfs and Bullhorn Bumper Black
Uni Filter w/EHS/Barkers BIG 3
13 Tooth front
9/16 L8ton sway and Alba stabilizer
2007 Rancher 420 Red
2wd Electric Shift
Uni Filter w/Hmf Slip on and Optimizer
Tusk Flex Handgaurds
Stevem12065 is offline
post #4 of 14 Old 02-17-2011, 12:41 PM
I also did the 13t before I did EHS/Barker big 3 and find I have no need to go back to 14t for the same reason.
post #5 of 14 Old 02-17-2011, 01:58 PM
I had a 13 tooth before I got the EHS/Barker big 3 also. I switched back to the stock sprocket. First gear was to short and if I wanted to crawl over something. Better not hit the already touchy throttle or it would friggin leap forward. Almost went off the side of the hill a couple times while riding pipelines. It's perfect now!
post #6 of 14 Old 02-17-2011, 02:59 PM
TRX700XXX's Avatar
I've been running big 3 and 13t but going to try 14t once I can ride next.
TRX700XXX is offline
post #7 of 14 Old 02-17-2011, 07:03 PM
I loved the 14t with the Big 3.
post #8 of 14 Old 02-17-2011, 07:47 PM
i love the 14 stock and i love the 14 with ehs big 3 better , but i live in the south where there is no slow technical trails hardly if i was to ride where all we do is crawl around in 1 gear or second i might have tried the 13 tooth its useless to me
post #9 of 14 Old 02-17-2011, 09:35 PM
I have switched a few times after the big 3, I still prefer the 13T. It makes 3rd perfect for the trails I usually ride.
post #10 of 14 Old 02-17-2011, 09:50 PM
Have you purchased an XX?
