Megacycle 106-X1 camshaft - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 02-22-2011, 01:13 PM Thread Starter
Brokenbones's Avatar
Intake valve lift .435 [email protected]'' 106 lobe center
Exhaust valve lift .415 [email protected]'' 107 lobe center
Anyone tried it?
Brokenbones is offline
post #2 of 14 Old 02-22-2011, 01:58 PM
08700xx's Avatar
I actually didnít even know this was an option, thanks for the info I'm pretty sure a lot of the Raptor guys use to run Megacycle cams and they worked well.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #3 of 14 Old 02-22-2011, 02:07 PM
boost addict's Avatar
Who sells them?
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #4 of 14 Old 02-22-2011, 02:16 PM
08700xx's Avatar
Megacycle cams is in CA but I didnt see this cam on their web site. http://www.megacyclecams.com/
(DL700)
Jody (Boost Addict)
08700xx is offline
post #5 of 14 Old 02-22-2011, 03:11 PM
i think that cam would work pretty well i didnt know it was option either. thats closer to the grind i did than the web cam 290 we will see how mine works here shortly
EHSRACING is offline
post #6 of 14 Old 02-22-2011, 03:54 PM
I did some searching and found out it's a xr650 cam. Still should work though.
Ed @
Chris & Mike
post #7 of 14 Old 02-22-2011, 03:59 PM Thread Starter
Hehe it is ;)
post #8 of 14 Old 02-22-2011, 04:03 PM
08700xx's Avatar
Are they like Web cams and need a core?
(DL700)
Jody (Boost Addict)
08700xx is offline
post #9 of 14 Old 02-22-2011, 04:05 PM Thread Starter
Page 32 on their web site. As you can see i'm not so satisfied with the hotcam stage 3... Can it be the one smooth1 used on is first build?
post #10 of 14 Old 02-22-2011, 04:07 PM
the stage 3 is designed for a stock head it worked well with that but once its ported it needs more lift
