Head bolts torque for hi comp piston - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 02-24-2011, 07:26 PM Thread Starter
Brokenbones's Avatar
I torqued down my head bolts to 49pi/lbs as per manual shop specified and it leak... I used a cometic gasket and did'nt used any kind of cooper glue on it. The head and cylinder has been surfaced as well. With a 11:1 piston do I have to torque it more , let say 55 pi/lbs?
Brokenbones is offline
post #2 of 13 Old 02-24-2011, 07:33 PM
HosRacn's Avatar
I just fired mine up and its not leaking, same piston.
Jeff Hoskins 72K
Brawley Radiator & Glass, Sand Posse, Imperial Valley Cycle Center, Scott Goggles, PowerMadd, CP Pistons, Graffik Graffiti, OMF, GoPro, Elka, Houser Racing, Fly Racing, Big Gun Exhaust and Renthal.
HosRacn is offline
post #3 of 13 Old 02-24-2011, 07:43 PM Thread Starter
It bubble in the overflow tank! Did you use a oem gasket?
post #4 of 13 Old 02-24-2011, 08:31 PM
boost addict's Avatar
I use the same piston and the same cometic gasket and 49ft/lbs is all you need. Thats alot if you ask me.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #5 of 13 Old 02-24-2011, 09:01 PM Thread Starter
I just check the torque wrench against another it look like to be not accurate
post #6 of 13 Old 02-24-2011, 09:54 PM
VelociRaptor's Avatar
It will bubble sometimes at first while its purping itself. If it still bubbles after an hour or so of riding then its may be an issue somewere.
Bo White
205-886-7043
VelociRaptor is offline
post #7 of 13 Old 02-24-2011, 10:13 PM Thread Starter
Yeah it bubble enough to over flow and well after an hour and it's not overheating the fan kicks in like before. I check the compression and it get 105psi. Tomorow I will open it cause I found some lil piece of rubber like on the cometic gasket
post #8 of 13 Old 02-25-2011, 10:38 AM Thread Starter
the sleeve droped .013 in the cylinder... so the gasket popped trought a water passage .For your it has been resleeved. I so angry I think I'm gonna k.......?%/?&?$*&*
post #9 of 13 Old 02-25-2011, 10:48 AM
Who resleeved it?
post #10 of 13 Old 02-25-2011, 11:05 AM
Why would you resleeve a stock cylinder, the are only 250.00 new?
Ed @
Chris & Mike
