Anybody try an E3 spark plug - Club700XX - Honda TRX700XX Forum
post #1 of 171 Old 03-07-2011, 02:24 AM Thread Starter
1dmbhonkey's Avatar
Thought I might give them a try. Cross refrenced the part # E3.64 if you wanna try um too. Somehow I doubt Ill "feel the burn" though. I guess its worth the $6 investment to find out.
1dmbhonkey is offline
post #2 of 171 Old 03-07-2011, 01:28 PM
DL700's Avatar
dont waste your money
DL700 is offline
post #3 of 171 Old 03-07-2011, 07:37 PM
Tory trx's Avatar
I'm not sure they really do anything other than drain your wallet. Also I dont think they last long. I guess for six bucks you can try but I doubt you will notice a difference.
Tory trx is offline
post #4 of 171 Old 03-07-2011, 08:17 PM
I'm using NGK BKR7EIX-11 Iridium plug and I like it. The stock one went bad after only about 20 hours.
carlstoys is offline
post #5 of 171 Old 03-07-2011, 08:20 PM
DL700's Avatar
thats a great replacemt plug and will net a little power.....but there is a better performing one we use in customers bikes
DL700 is offline
post #6 of 171 Old 03-07-2011, 08:36 PM
boost addict's Avatar
A better plug and wire/boot has to help.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #7 of 171 Old 03-07-2011, 09:17 PM
92K1500's Avatar
And that would be.........................................
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #8 of 171 Old 03-08-2011, 07:22 AM
what plug would that be?
08 Honda 700xx
Installed
Britalican is offline
post #9 of 171 Old 03-08-2011, 10:47 AM
TRX700XX's Avatar
Just to be straight up i put the E3 plug in my 2002 silverado pick up and it felt weak compared to my previous acdelco irodiums. The E3 electrode was white (meaning good air/fuel mixture) but it caused my truck to throw a rich code on bank1 and bank2. It even managed to throw up an EVAP code. Since i just replaces the plugs 6k miles ago i didnt expect them to be the cause, but after some troubleshooting i pulled out the E3s and put in the ACDelco Irodiums and cleared the DTCs.... No more problems to sum it up personally that E3 plug SUCKS
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #10 of 171 Old 03-08-2011, 11:37 AM
DL700 what plug would u suggest then?
