Anybody running race gas in thier 700xx?? - Club700XX - Honda TRX700XX Forum
post #1 of 18 Old 03-09-2011, 05:20 PM Thread Starter
Wondering if anybody is running any race gas in thier 700XX. If so what are you running. I can get 100 low lead AV Gas wondering if this would or could mess up the F.I.
Gregg Foster is offline
post #2 of 18 Old 03-09-2011, 05:21 PM
08700xx's Avatar
I only run race gas in my XX. I use VP C12
(DL700)
Jody (Boost Addict)
08700xx is offline
post #3 of 18 Old 03-09-2011, 05:28 PM Thread Starter
Did you notice any difference running the race gas?
post #4 of 18 Old 03-09-2011, 05:33 PM
boost addict's Avatar
I am running Vp Streetblase 100 in my stock bore and Vp C12 in the big bore. Not sure about the av gas.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #5 of 18 Old 03-09-2011, 05:39 PM
08700xx's Avatar
I did too much at one time to know how much of a difference the race fuel made. I run nitrous and a 12:1 piston so I have to run race fuel.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #6 of 18 Old 03-09-2011, 05:44 PM
VP100 (aka StreetBlaze 100)
Oxygenated with ethanol, this CARB-legal fuel is engineered for high-performance ATVs and other powersports. VP100 makes substantially more power than pump gas as well as better throttle response, a critical factor when navigating jumps, streams or around trees. Its higher octane also offers better detonation protection for extreme conditions such as slogging through mud or sand washes with the throttle pinned. When unleaded fuel is required, VP100 is a very cost-effective option in terms of performance gained for dollars spent compared to pump gas
Ed @
Chris & Mike
post #7 of 18 Old 03-09-2011, 05:59 PM Thread Starter
Wow the Nitrous on that beast has to be a white knuckle ride!!! What a rush!!! Guess that would be a lil hard to tell with such a big change...
post #8 of 18 Old 03-09-2011, 07:04 PM
crisco's Avatar
Running race fuel is a waste of money unless your running higher compression that needs the extra octane.
2009 Raptor 770R
Monster duals, FCI, PC3, +5 Hotrods, Kenz 105mm cylinder, CP 10.75:1, Barker RHC14 cam, Kibblewhite springs, Trex II port, +3 throttle body, Dynatek programmable, evac valve, 22" Haulers on Douglas wheels
crisco is offline
post #9 of 18 Old 03-09-2011, 07:33 PM
.. you should only run it on a high compression motor. otherwise, you're just throwing your money away!
post #10 of 18 Old 03-09-2011, 07:45 PM
TRX700XXX's Avatar
Or if you love the smell haha
TRX700XXX is offline
