need help identifying piston compression - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 03-09-2011, 06:47 PM Thread Starter
I bought an 11.0:1 cp piston from Alba. there are 2 stickers on the box, one with the part number for the 11.0:1 piston, and one with the part number for the 12.0:1 piston. Alba is telling me that they put the wrong label on the box by mistake and it is in fact the 11.0:1 piston that I ordered.
So what I need to know is if there is any way for my to identify the true compression of the piston by looking at it. the only thing i see on the piston itself is "X100a" does this mean anything? thanks for any help!
08 Honda 700xx
Installed
Britalican is offline
post #2 of 7 Old 03-09-2011, 07:01 PM
crisco's Avatar
Is CP making the xx pistons corrected deck height? If not either one should run fine on pump gas. I could be wrong though...
2009 Raptor 770R
Monster duals, FCI, PC3, +5 Hotrods, Kenz 105mm cylinder, CP 10.75:1, Barker RHC14 cam, Kibblewhite springs, Trex II port, +3 throttle body, Dynatek programmable, evac valve, 22" Haulers on Douglas wheels
crisco is offline
post #3 of 7 Old 03-09-2011, 07:09 PM
boost addict's Avatar
Your Cp piston should have came with a specification sheet. Look for the shelf part # and tell us what it says.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #4 of 7 Old 03-09-2011, 07:37 PM Thread Starter
good call, not sure why I dint notice that. its the M2075, so it is an 11.0:1
thanks Jody!
08 Honda 700xx
Installed
post #5 of 7 Old 03-09-2011, 07:40 PM
No problem glad to help
Ed @
Chris & Mike
post #6 of 7 Old 03-09-2011, 09:01 PM
If you post a picture I can tell you which it is.
post #7 of 7 Old 03-10-2011, 06:07 AM Thread Starter
thanks, but its all figured out.
08 Honda 700xx
Installed
