PC5 problem - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 03-09-2011, 08:22 PM Thread Starter
Brokenbones's Avatar
PC5 problem
Anyone had any trouble with the pc5. First look at my signature. Ok I loaded a map from the dynojet site as per my mods and the bike is running like crap it bog like a lean bike until 4000 rpm. The bike idle like a champ. Then as soon as I unhook the pc5 the bike I snap the throtle and run well until high rpm turning lean. Also I hooked again the pc5 but loaded the blank map and still bug, can the pc5 be defective brand new?? Also my bike is a 2008, I shoud'nt have trouble even if my year was'nt listed for the pc5? I real disapointed:(
Also the basic like the ground, connectors and tps calibration has been checked and carefully...
Thank for any input
Brokenbones is offline
post #2 of 8 Old 03-09-2011, 08:30 PM
you need to get it to a dyno and fine tune it
post #3 of 8 Old 03-09-2011, 08:46 PM
boost addict's Avatar
Which base map are you running?
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #4 of 8 Old 03-09-2011, 09:12 PM Thread Starter
The alba with the full exhaust, the bike is not driveable it bug so bad, I just can't believe the thing is not defective.
post #5 of 8 Old 03-10-2011, 12:18 AM
I loaded that same base map and had no issues at all. I am thinking that since it is still happening when you load the blank map that it has to be an issue with the PCV. I would tell you to check connectors ect but as you said you have I would call DynoJet and see what they say. I have called them before about my PCIII for my GSXR-1000 and they were very helpful. It doesnt hurt to see what they have to say. If that doesnt work, contact the place you bought it from and tell them it is faulty and you want to exchange it
post #6 of 8 Old 03-10-2011, 04:23 PM Thread Starter
Ok guys had a call to Jay at dynojet and found that the rpm extend fonction was checked enable. unchecked it to disable and problem solve, now heading to the dyno! Thanks for your time;)
post #7 of 8 Old 03-10-2011, 04:36 PM
See. Told you they were helpful
post #8 of 8 Old 03-10-2011, 06:06 PM Thread Starter
Yeah you told me so;) that why I enjoy this site actually this the only place I post!
