possibly overheating - Club700XX - Honda TRX700XX Forum
post #1 of 18 Old 03-21-2011, 07:46 AM Thread Starter
kms15's Avatar
my bike seems to start to steam after getting the bike warm. it looks lke its coming out the side of the radiator but coolant level has not droped. im just curious if someone else has or had problems like this before.
kms15 is offline
post #2 of 18 Old 03-21-2011, 07:56 AM
AusTrx700xx's Avatar
whats the weather like where your riding when this is happening? caus this will happen if its raining or you have moisture in the fins of the radiator, is there any staining on the radiator
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #3 of 18 Old 03-21-2011, 08:12 AM Thread Starter
kms15's Avatar
the temp here ha been around 50 to 60 degrees. i went riding the other day and the bike started dripping coolant so i towed the bike in. i got it back to my garage and pulled the plastics off, started the bike and nothing was leaking. i rode the bike yesterday and it started steaming out of the radiator again. it seems to me that theres a pin hole in the radiator itself but ther is no sign off a puncture.
kms15 is offline
post #4 of 18 Old 03-21-2011, 08:30 AM
when you say it was dripping coolant, it was actually green? caus this seems a bit odd, so the level in the radiator and the overflow bottle hasnt changed at all?
post #5 of 18 Old 03-21-2011, 09:02 AM Thread Starter
kms15's Avatar
exactlly whats happening. its confusing the hell out of me. i thought about pressure testing the radiator but id have to block off the resavoir to do that. any suggestions?
kms15 is offline
post #6 of 18 Old 03-21-2011, 09:12 AM
vice grips will block the resivour off, and you will find most pressure testers will actually seal below where the overflow fitting is, but it couldnt hurt to try, im not sure what to say on this on this one. is all your getting out of the radiator is steem? and its just from one side
post #7 of 18 Old 03-21-2011, 09:21 AM Thread Starter
kms15's Avatar
i only smelled coolant the first time,thats why this is so confusing.im wondering if the thermostat is getting stuck also.like i said i happened 2 out of 3 times i started it.i am scared to ride the damn thing because i dont want to blow it up,and i want to make sure its the radiator casing this problem before i replace it. i would hate to buy a radiator and something else is causing this issue.
kms15 is offline
post #8 of 18 Old 03-21-2011, 09:27 AM
if you had thermostat issues the coolant in your rad would be cold and the coolant in your engine would be boiling, there are 2 ways to test a thermostat, one if to run the bike and as it warms up feel the 2 rad hoses, one will warm up before the other, and then when the engine gets to running temp the thermostat will open and the temps will get close to even, the other way is to remove the thermostat and boil water in a pan, when the water is boiling, place the thermostat in the water and the centre section should open, if not you have a thermostat issue
post #9 of 18 Old 03-21-2011, 09:29 AM
but a pressure test is only way to find where the leak is, warming the engine before you do the pressure test wouldnt be a bad idea
post #10 of 18 Old 03-21-2011, 09:30 AM Thread Starter
kms15's Avatar
thanks for the help
kms15 is offline
