Is it normal for an aftermarket header to glow red? - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 03-21-2011, 07:22 PM Thread Starter
I just installed my ehs big 3 and had it just idling and I saw it stArt to glow red right at the head/ exhaust port, Granted it was at night but I never noticed my stock header glow. I thought maybe it's running lean but there is no pinging etc and the bike runs strong as hell after the mods, Just wanna make sure I'm on the up and up.
mike01z is offline
post #2 of 15 Old 03-21-2011, 07:29 PM
traitor08's Avatar
My stock setting my factory head pipe would glow. Put programmer on and it doesn't glow. I would say you are a little lean, is aftermarket header thinner metal than factory header.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #3 of 15 Old 03-21-2011, 07:37 PM Thread Starter
Yeah it does seem thinner
mike01z is offline
post #4 of 15 Old 03-21-2011, 07:48 PM
traitor08's Avatar
Thinner metals require less heat to glow, they lso cool off a lot quicker. I say check plug, if it its light brown should be ok. But other more knowledgeable guys will chime in.
MY RIDES
post #5 of 15 Old 03-21-2011, 10:56 PM
its normal to see them glow at night a little especially if it doesnt have any air moving across it. you are not lean if you have it setup like we send it
EHSRACING is offline
post #6 of 15 Old 03-22-2011, 06:37 AM
Mines glows at night with the EHS big 3 at the recommended setting. I think it's just normal.
post #7 of 15 Old 03-22-2011, 08:27 AM
Yeah, you are fine. Mine glows....especially when I am in a tug of war w/ a raptor 700. It really glows then
post #8 of 15 Old 03-22-2011, 11:05 AM
atleastitsnotaford's Avatar
my stock head pipe glows at night
atleastitsnotaford is offline
post #9 of 15 Old 03-22-2011, 01:55 PM
Quite normal... also good for heating up lunch or dinner. Wrap a Piroshki or hot pocket in aluminum foil and set on hot pipe... wait a few minutes and you have lunch.
post #10 of 15 Old 03-22-2011, 02:14 PM Thread Starter
cool thanks guys
mike01z is offline
