13 tooth front sprocket - Club700XX - Honda TRX700XX Forum
post #1 of 25 Old 03-27-2011, 07:31 PM Thread Starter
i am new to this website and am soon going to buy a 700 xx and was wondering what is the top speed difference with a 13t front sprocket from the original 14t sprocket, thanks.
chrisneitzel is offline
post #2 of 25 Old 03-27-2011, 07:50 PM
holy700xx's Avatar
Like 7MPH, do search on this its been beaten to death
holy700xx is offline
post #3 of 25 Old 03-27-2011, 07:53 PM Thread Starter
thanks. is it worth it for the extra acceleration?
post #4 of 25 Old 03-27-2011, 08:37 PM
Qaz
first three things i would get would be 13 tooth a uni air filter and a L8ton racing 11/16" sway bar
for under 300 dollars total probably the best money you will spend on your quad
Qaz is offline
post #5 of 25 Old 03-27-2011, 09:00 PM
13tooth is for more low end. Depends on type of riding you will be doing. The 14t, wont hardly hold a idle on its own, and the 13t has no problem. It will almost will idle up my trailor! For $20 or under it's well worth the swap! And if you dont like change it back, it's like just a few min task.
post #6 of 25 Old 03-27-2011, 11:36 PM
7mph is the average top speed loss. I tried the 13 tooth yesterday for the first time. It made 1st and 2nd gear completely worthless. hit the rev in second gear in less then half a second. made the bike feel slow. I really hated it soooo much. Most on here seam to love it, but its just not for me. Switched back to the 14 after an hour ride, and it was night and day. now I'm curious to try a 15.
08 Honda 700xx
Installed
Britalican is offline
post #7 of 25 Old 03-27-2011, 11:57 PM
92K1500's Avatar
Well most everyone on here that loves the 13t has a stock engine too.
When you build the engine as much as you have you don't need the 13t.
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #8 of 25 Old 03-27-2011, 11:59 PM
... was just about to say that!
post #9 of 25 Old 03-28-2011, 12:01 AM
08700xx's Avatar
I love my 15t
(DL700)
Jody (Boost Addict)
08700xx is offline
post #10 of 25 Old 03-28-2011, 12:03 AM
yeah, thats what I figured, thats why I made sure to say that others on here love it, but not for me. lol
08 Honda 700xx
Installed
