Hex key size? - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 04-05-2011, 08:53 PM Thread Starter
Send a message via Yahoo to Robotaz
Hex key size?
I'm doing my first valve clearance check and, of all things, the dang hex bolt to get to the crank is too big for the keys I have. Can someone tell me the size please? Or if I just knew if it was standard or metric that would help, too. I have to go buy new ones so I guess if I new which type to buy I would be covered.
Thanks in advance for any help.
2008 Honda TRX700XX
2008 Yamaha Wolverine 350
Robotaz is offline
post #2 of 15 Old 04-05-2011, 09:05 PM
all the bolt on honda are metric
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #3 of 15 Old 04-05-2011, 09:06 PM
AusTrx700xx's Avatar
its definatly metric, i think its a 8mm or 10mm from memmory, then its a 17mm to turn the crank
All readyto roost thanks to
Mike at Quadparts.com.au
Team IMS imsproducts.com
George at MonsterLab Atv
Kimberly Motorcycles
Minshull Mechanical Repairs
AusTrx700xx is offline
post #4 of 15 Old 04-05-2011, 09:24 PM Thread Starter
So if I buy a set of large metric hex keys I should be fine. Is there a certain direction the crank has to be turned? I'm assuming it's supposed to turn in the same direction that it runs, but I don't know what that is.
2008 Honda TRX700XX
Robotaz is offline
post #5 of 15 Old 04-05-2011, 09:50 PM
Brokenbones's Avatar
Counter clock wise
Brokenbones is offline
post #6 of 15 Old 04-05-2011, 11:34 PM
you got the manual? it as all the info you need to do just about everything to the xx,
As people on the forum will help you just simetimes you have to wait a while to get the info.
The manual is available from the forum to download free in the "how to" section
Most metric allan key sets should go up to 10mm but having a 12mm and 14mm can come in handy
if you dont have a metric socket set the rough metric to imperial sizes are: 7/16=11mm 1/2=13mm 9/16=14mm 5/8=16mm 11/16=17mm 3/4=19mm 7/8=22mm and 15/16=24mm
these sizes will work on most bolts but having the correct metric sockets would be better
post #7 of 15 Old 04-06-2011, 01:25 AM
b.courtney_700xx's Avatar
what bolts on any model anything arent fricken metric anymore? shit we have to accomidate the chinese mexican, koreans, and all the others. makes it easier for them when the CEOs and other various big wigs of big business send our work over to them.
sorry didnt mean to thread jack... back on topic...
2008 trx700xx
dg steel series nerf bars
13t renthal
3D powertip
razrs on her feet
b.courtney_700xx is offline
post #8 of 15 Old 04-06-2011, 01:35 AM
the rest of the world uses metric for everything. we are the weird ones that had to go and make things difficult. lol
08 Honda 700xx
Installed
Britalican is offline
post #9 of 15 Old 04-06-2011, 06:56 AM Thread Starter
I printed the manual and couldn't find which way to turn it or how big that hex bolt key is.
2008 Honda TRX700XX
Robotaz is offline
post #10 of 15 Old 04-06-2011, 06:57 AM Thread Starter
My 2009 Mazda 5 has metric and standard as it is a hybrid of Ford and Mazda parts. It's a PITA.
2008 Honda TRX700XX
Robotaz is offline
