High Compression Piston and Cam - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 04-12-2011, 08:41 AM Thread Starter
I am interested in getting a 12:5 to 1 high compression piston and a stage 3 hot cam installed on my 700!! Just looking for feedback or thoughts (good or bad) before i pull the trigger. Example: Gas, other motor work or other parts I would need to install. From looking at all the posts I think I'm in the right spot to get good advice. Thanks!!!!!!!!
Just Ride!!!!!!!
kbittle2 is offline
post #2 of 8 Old 04-12-2011, 09:11 AM
boost addict's Avatar
With a 12.5:1 piston you are going to need run race gas(cam2 or C10).The hc 3 is a very mild cam, so no need for springs or hardwelded rockers. You will also need a pc3 or pc5 for tuning IMO.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 8 Old 04-12-2011, 09:25 AM
rockingham, ?
EHSRACING is offline
post #4 of 8 Old 04-12-2011, 10:36 PM
the 12.5:1 piston wont get u much extra unless u do a lot of other mods. just going to make u have to run race fuel. go with an 11:1 piston unless u have plans to do some port work and better cam, springs, rockers in the near future to get the full potential of the piston.
08 Honda 700xx
Installed
Britalican is offline
post #5 of 8 Old 04-13-2011, 01:00 AM
08700xx's Avatar
What mods do you have right now? I was told with 12 5 1 you can get away with 100 octane but they recommended 110. I'm at 12 1 and I run VP C12 with my build. Like Britalican said it just depends on what you want out of it and how much you are willing to spend on fuel. I heard the HC3 works pretty good for the price with stock heads but Web cams work a lot better in ported heads, I would get a +3 throttle body with the cam and piston.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #6 of 8 Old 04-13-2011, 08:42 PM Thread Starter
My current mods are are only fmf exhaust and programmer and K&N air filter. Not really worried about how much i spend on gas. Just looking to get a little more power overall but I dont want to pour 2000 dollars or more into. I was told i could get the HC piston and a cam for for about 350 and get it installed for about 250. havent priced the springs or rockers. looking to keep the price parts and labor under 1000. Yes I am from rockingham, nc
Just Ride!!!!!!!
kbittle2 is offline
post #7 of 8 Old 04-16-2011, 07:50 PM
700Xxrida's Avatar
how can the stock high performance dirt bikes run such a high compression ratio on pump gas
13.2 to 1? http://powersports.honda.com/2011/cr...fications.aspx
honda 700xx 250ex cr 250 ride red or dont ride at all
700Xxrida is offline
post #8 of 8 Old 04-17-2011, 02:14 AM
crisco's Avatar
all depends on cam profile, head design, true compression ratio, etc.
2009 Raptor 770R
Monster duals, FCI, PC3, +5 Hotrods, Kenz 105mm cylinder, CP 10.75:1, Barker RHC14 cam, Kibblewhite springs, Trex II port, +3 throttle body, Dynatek programmable, evac valve, 22" Haulers on Douglas wheels
crisco is offline
