MORE POWER!! Please Help - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 04-16-2011, 05:44 PM Thread Starter
Qaz
I was wondering if there is anything else i can do to get a little bit more power from my quad i have uni filter, 3d tip and the special sparkplug. I do not want to run a fuel controller.......could i maybe run the powerbomb header or anything else i can do to get a little more without a controller. looking for mostly bottom to mid power.
thanks
Qaz
Qaz is offline
post #2 of 15 Old 04-16-2011, 06:10 PM
13 tooth front sprocket wont give u more power, but it might make it feel like it.. thats about it without a fuel controller. I wouldn't recommend the powerbomb without a controller either. these quads already run lean.
08 Honda 700xx
Installed
Britalican is offline
post #3 of 15 Old 04-16-2011, 07:54 PM
traitor08's Avatar
I would highly recomend fuel controller, that alone will give alot. I put the ehs one on and set it .5 lower on fuel setting for factory+ehs lid settings(I only have the controller). Night and day difference, I can idle around in first with the 14t, never could do that stock. Can't wait to get the rest of the big3. But you can't really do much without controler, like adding parts to a carb atv without rejetting.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #4 of 15 Old 04-16-2011, 08:35 PM Thread Starter
Qaz
so you say just the controller will add power?
Qaz is offline
post #5 of 15 Old 04-16-2011, 09:39 PM
08700xx's Avatar
Yes it will add more power.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #6 of 15 Old 04-16-2011, 09:52 PM
Good to know, and how big of a deal is it to hook one up?
post #7 of 15 Old 04-16-2011, 10:20 PM
Takes five minutes! It's simple
post #8 of 15 Old 04-16-2011, 10:33 PM Thread Starter
Qaz
what controller would you guys recommend ? i need something simple and durable cant afford to do it twice
Qaz is offline
post #9 of 15 Old 04-16-2011, 10:44 PM
I have the EHS controller and it works great.
post #10 of 15 Old 04-16-2011, 10:56 PM
08700xx's Avatar
The EHS one is probably going to be the most user friendly for you and the people that have one love it.
(DL700)
Jody (Boost Addict)
08700xx is offline
