bb vs sb - Club700XX - Honda TRX700XX Forum
post #1 of 101 Old 04-17-2011, 07:30 PM Thread Starter
boost addict's Avatar
bb vs sb
This is going to take me some time to put up all the dyno sheets, so please be patient. Daniel at HDD hooked me up with the first +3 tb and all you guys know about the spark plug, i also added a k&n filter. Here are the results of these 3 changes. Thanks Daniel for all your help and knowledge This is my sb with 11:1 cp piston and pump gas. 61.04rwhp/46.51tq
The bb maxed the stock fuel injector out. Daniel sent me a bigger injector( 600cc)with a PVC base map which had a perfect A/F until until 7000rpm and need just a little fuel added. This is the bb vs sb dyno sheet. Thanks to Bo, Daniel and Chris for all your help bb was 63.54hp/51.35
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #2 of 101 Old 04-17-2011, 08:34 PM
08700xx's Avatar
I'm glad you finally finished your builds. I can't see so great on my phone but the power curve looks great on both. its time for some drag racing now.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #3 of 101 Old 04-17-2011, 08:42 PM
VelociRaptor's Avatar
So you gained over 5hp by swapping out to a +3 TB!?
Bo White
205-886-7043
VelociRaptor is offline
post #4 of 101 Old 04-17-2011, 09:02 PM Thread Starter
Yes the +3 tb added the power with a modded intake tube.
Ed @
Chris & Mike
post #5 of 101 Old 04-17-2011, 09:21 PM
Bet they haul some serious arse! Whats next???
post #6 of 101 Old 04-17-2011, 09:47 PM Thread Starter
It's already in the works! I just need a couple of sponsers
Ed @
Chris & Mike
post #7 of 101 Old 04-17-2011, 09:53 PM
2.5 hp over the sb? can you post what was done to each?
post #8 of 101 Old 04-17-2011, 09:56 PM
DL700's Avatar
what are the full build specs on each?
same exhaust/ intake tb cam?
that should be a nice increase in grunt from the bb but what concerns me is the top end 7500+ rpm eing that the bb and sb are the same hp in that area id go bigger on the head porting
DL700 is offline
post #9 of 101 Old 04-17-2011, 10:15 PM Thread Starter
pump gas s/b= PCV or PC3 IS A MUST!!! Web 290 cam, Web Hardwelded Rockers, KB springs,+1 pp head, HDD bore tapered +3 tb, modded intake tube for bored tapered tb with K&N filter that fits around the intake sleeve in the air box. HDD clutch and HDD spark plug.
C12 race gas bb=PCV or PC3 IS A MUST!!! Web 290 cam, Web Hardwelded Rockers, KB springs,+1 pp head, HDD bore tapered +3 tb, modded intake tube for bored tapered tb with K&N filter that fits around the intake sleeve in the air box. HDD clutch and HDD spark plug, HDD 600cc blue fuel injector.
Ed @
Chris & Mike
post #10 of 101 Old 04-17-2011, 10:20 PM
Why did he start the dyno runs at 4,000 rpm's???
Sorry i couldn't resist! ...Lord i appologize...
