700XX Fan Modifications - Club700XX - Honda TRX700XX Forum
post #1 of 2 Old 04-21-2011, 12:32 AM Thread Starter
Ok I did some searching on the site and cant find anything on it but I thought I saw someone doing something with this before. Has anyone done any moding of the XX cooling system? I was thinking either adding a switch to have the fan come on whenever I want in addition to automatically. Kinda like an override or doing something like swaping out either the whole fan or just the fan blade and sheath for a larger one. It would be nice for riding on those tight slow trails to keep the beast cool. I was just wondering if anyone has done anything with this before
post #2 of 2 Old 04-21-2011, 03:36 AM
DL700's Avatar
we used to make a fan kit for the Raptor but basically would work on any bike
basically find the fan relay... it should be switched by a negative signal from the ecu
piggyback a wire onto this terminal and run it to a thermo switch ...
http://www.kfx450hq.com/forums/engin...es-solved.html
http://www.kfx450hq.com/forums/impor...stall-how.html
DL700 is offline
