New Oil with New Cam?? - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 04-24-2011, 05:23 PM Thread Starter
1dmbhonkey's Avatar
I recently put in a new hotcam, and the thing makes a valve "ticking" sound (the lash is set right) when the bike warms up. I was thinking I might try some 20W50 to reduce the noise. Anybody think this is a good idea??
1dmbhonkey is offline
post #2 of 19 Old 04-24-2011, 07:29 PM
too thick . . .
post #3 of 19 Old 04-24-2011, 09:57 PM
quadmonkey700xx's Avatar
x2 ^
quadmonkey700xx is offline
post #4 of 19 Old 04-24-2011, 10:22 PM
I was told to try some full synthetic to help quiet the ticking sound the hot cams make. I would stick to a 10w-40 full synthetic.
post #5 of 19 Old 04-25-2011, 02:17 AM Thread Starter
1dmbhonkey's Avatar
Have you tried it yet?? That stuff is like $9 a quart!! lol ..... let me know if it helps
post #6 of 19 Old 04-25-2011, 05:07 AM
I think I'm gonna stick with gn-4 and just deal with the noise.
post #7 of 19 Old 04-25-2011, 04:52 PM
TRX700XXX's Avatar
What makes the hot cams tick?
TRX700XXX is offline
post #8 of 19 Old 04-25-2011, 08:38 PM
I was told it is the stock springs working harder due to the cam having more lift and duration. It kinda sounds like the valves are out of adjustment.
post #9 of 19 Old 04-25-2011, 08:46 PM
TRX700XXX's Avatar
So would stiffer springs get rid of it? I've been thinking about hot cam stage 2.
post #10 of 19 Old 04-25-2011, 08:52 PM
Im not sure? I have heard the Webb cams are quieter but they use stiffer springs. I guess it's possible. The hot cams are designed to work with stock springs,piston and rockers though? It's not that bad though. My Barker pipe is Friggin loud as hell! So I don't really notice It that much.
