sprocket setup - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 04-27-2011, 09:42 AM Thread Starter
Garrett22's Avatar
sprocket setup
from riding in the dunes a lot more here lately I've been asking other people questions about what they have done to their bikes. (especially the ones that win) They all say that the speed is in the gearing, most of them have went down one in the front and up two in the back, so ive been thinking about doing it too, or something similar. what do ya'll think the best sprocket setup for drag racing the xx in about 300' strips?
08 700xx black & silver
-barkers exhaust
-alba programmer
-uni filter
Garrett22 is offline
post #2 of 13 Old 04-27-2011, 10:47 AM
TRX700XX's Avatar
1/4 mile i run 15t front and a 36t rear... but thats pavment
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #3 of 13 Old 04-27-2011, 05:21 PM
Its hard to say what sprocket to use because it depends on the power you have to pull it. I personally am running a 15 tooth front and stock rear sprocket and I like it alot.
post #4 of 13 Old 04-27-2011, 09:45 PM Thread Starter
Garrett22's Avatar
well, i may just buy a couple different ones and try em all out. does anyone know someone that sells rear sprockets for less than 50 bucks? lol
-barkers exhaust
-alba programmer
-uni filter
post #5 of 13 Old 04-27-2011, 10:03 PM
well a 12t front is the equivalent of down 1 in the front and up two in the rear
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
post #6 of 13 Old 04-28-2011, 04:32 PM
It depends what you want and the build you have. If you only have the big 3 I would say stay with the stock gearing. 15 tooth I dont think it will pull as hard with the big 3 and 13 tooth is too much low end and too short of gears for drag racing. And I havent been able to find anything very cheap for the rear sprocket at all.
post #7 of 13 Old 04-30-2011, 10:20 AM
Like crash said 13 tooth makes the gears too short and its nohing but wheels up. However I:'m running the 15 tooth and to me it works really well. It also tops out at 83 MPH.
post #8 of 13 Old 04-30-2011, 10:26 AM
Heika's Avatar
13 helps alot in trails, idle throu the terrain :P had that on my last bike, what ive read its bout the same on the 700xx, ordered one from RMATVMC
Honda Trx 700xx Black And Grey
Mods:
L8ton Sway Bar 11/16"
Alba Pro Elite Bumper
Alba Pro Elite Nerfbars
J n J Skidplates
Supersprox Front Sprocket 13 Tooth
Reverse Rev Limiter Removed
Trailtech Vapor
Powermadd Black And Chrome
Hidlights-5000K
Heika is offline
post #9 of 13 Old 05-01-2011, 01:15 AM
TRX700XX's Avatar
Tire size also makes a difference... I run 22 in tires with 15 front and 36 rear. Im hoping to do a few more things for power and hit triple digits
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #10 of 13 Old 07-12-2012, 04:34 PM
Where did you find the 36 sprocket ???
727xx is offline
