HID bulbs - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 05-02-2011, 10:30 PM Thread Starter
HID bulbs
Okay guys, im lookin to buy some stock replacement bulbs on ebay i found and was wondering if these really are "plug and play" style bulbs as the wattage has me worried. The manual says the stock bulbs are 12V - 30/30W and these replacement bulbs also say 12V, but it says their drawing wattage stays the same but output is 100-90W?!?!?!? I honestly dont know what to go by, can someone help me with this? will these work or will they fry my system or damage it in some way?
P.S here`s the link to the bulbs
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=350459200753
Fenix is offline
post #2 of 7 Old 05-02-2011, 11:55 PM
92K1500's Avatar
Don't get those. Those are just colored halogen bulbs with crazy high wattage to get the light output of HID without getting an HID kit.
They will draw way too much power from your elec system. And they will also put off a ton of heat which can melt your housing.
Plus they aren't even the correct bulbs. The 700XX takes an H6M.
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
Go there, choose 35W, pick the color you want and then add it to your cart. You don't need any of the other junk.
And I'd suggest 5 or 6000k for the color.
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #3 of 7 Old 05-03-2011, 03:46 AM
ranger19jn's Avatar
yeah the bulbs are wrong like stated above the H6m is what you want ive had good and bad luck with the cheap ebay ones one set works great while the other set flickers all the time it is mostly because we had to splice the harness and the cheap wire didnt accept solder very well if at all
also I have a set of the ballest and igniter in one set that has a short in the casing it will ground out if touching metal i had to wrap it in electrical tape to keep it from catching my car on fire once lol I would stick to the standared slim ballest
as far as color I run 6000k and love them plenty brite with a slite blue tint
5000 is pure wite and the brightest so it all depends on what you want if you dont care how brite it is you just want the color 8000 or 10000 may be better for you they will still be brighter than stock but have alot more color to them
08 trx700xx lot's O mod's
08 ktm 525xc modded
08 yamaha 450 lightly modded
05 grizzly 660SE (sold)
11 rzr s (sold) and missed
sponsors:
Manford Auto Supply (NAPA)
Teixeira Tech:
L8aton Racing:
Fox Racing:
powermadd:
ranger19jn is offline
post #4 of 7 Old 05-03-2011, 06:20 PM Thread Starter
thanks alot guys, i knew something was up and that HID bulbs weren't just plug and play
just one more question, i`d take it the kit is waterproof or should i do something to make it so?
Fenix is offline
post #5 of 7 Old 05-05-2011, 10:48 AM
TRX700XX's Avatar
The 55w HIDs are great and are bright as heck.. however after a long night ride we pulled up to rinse the quads off and when the water hit my plastic headlight lens it cracked across it like it was glass
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #6 of 7 Old 05-05-2011, 10:35 PM
92K1500's Avatar
IIRC the slim ballasts from DDM are waterproof.
And yeah the 55W are too hot for small housings. They only recommend using them in vehicles with large housings.
2008 Honda TRX700XX
92K1500 is offline
post #7 of 7 Old 10-03-2011, 12:10 AM Thread Starter
Thanks everyone, i went with the 8000k`s cuz of the pretty color, they`re gorgeous
Fenix is offline
