starting issues - Club700XX - Honda TRX700XX Forum
post #1 of 14 Old 05-05-2011, 12:13 PM Thread Starter
Jake777's Avatar
starting issues
Wondering if anyone has this same problem, or a fix for it.
When I turn the key then press start, engine kinda chugs a few times before it fires up. Almost like its having problems turning over. It does this especialy when the bike is hot, or warmed up. I took it to Honda and they said they couldnt get the bike to do it, go figure... It does it to me everytime I stop on the trail, and restart...
I just put on EHS big 3 the other day, and was hoping the EFI would take care of it, but it hasnt... Any help would be much appreciated.
Thank you
Jake777 is offline
post #2 of 14 Old 05-05-2011, 12:17 PM
are you pulling the clutch all the way in? If not try that and see if it helps any.
post #3 of 14 Old 05-05-2011, 12:20 PM
Also how many hours are on your bike? Have the valves been adjusted? When i adjusted mine the first time. My intake valves were too tight. Exhaust was fine though.
post #4 of 14 Old 05-05-2011, 12:21 PM Thread Starter
Jake777's Avatar
yes, pulled all the way back as far as it goes... Still seems like its struggling to turn over two or three times before it fires up.
Jake777 is offline
post #5 of 14 Old 05-05-2011, 12:23 PM Thread Starter
Jake777's Avatar
Right around 100 hours. I've had it in at Honda for the tune up at 20 hours, and then again three weeks ago for the 100 hour tune up. Unless the Honda shop is lying to me and I'm paying them to do nothing, which wouldnt supprise me...
Jake777 is offline
post #6 of 14 Old 05-05-2011, 12:26 PM
My bike does has a hot start problem but i have a higher lift cam in mine. I might buy a stronger battery.
post #7 of 14 Old 05-05-2011, 01:20 PM Thread Starter
Jake777's Avatar
So, about a new battery. Any sugestions for a stronger battery, where to buy, power needed, etc.?
Jake777 is offline
post #8 of 14 Old 05-05-2011, 03:46 PM
Some guys are using a CBR1000rr battery for extra Cranking amps. DL700 is talking about getting some custom batteries made up That are light weight.
post #9 of 14 Old 05-05-2011, 05:50 PM
08700xx's Avatar
I ordered my battery from DL700
(DL700)
Jody (Boost Addict)
08700xx is offline
post #10 of 14 Old 05-05-2011, 06:51 PM
What kind did you order from DL700, type, size, etc... specs please
Thanks
I found it "If I only would have read a little further down in the new posts"
Seabass is offline
