High power, light weight battery - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 05-05-2011, 01:41 PM Thread Starter
DL700's Avatar
SO who would be interested??
it seems like a common problem with the 700xx to crank over slow and mainly due to the battery itself, so who would be interested in a light weight high power custom battery
this is a similar unit used in the raptor 700
LI cell technology..I can get them custom made for the xx application and boost capacity as well
ANTI GRAVITY BATTERIES 4600 series
Easily cranks over HI COMP BIG BORE/ STROKE motors
Light weight and cost effective
Lithium Based a123 cells
Studs for easy/ hassle free install
Foam jackets to fit tightly in OEM location
weight savings of 5.75 lbs over stock
LTR 450 SUZUKI
DL700 is offline
post #2 of 19 Old 05-05-2011, 01:52 PM
I'm interested definitely! Will it save 5.75 lbs on the XX too?
post #3 of 19 Old 05-05-2011, 01:58 PM Thread Starter
DL700's Avatar
im thinking we can do a 12 cell... for a little extra power for the colder weather guys
12v 6.9Ah 12-cell Lithium Motorsports Battery
2.25 lbs 360 CCA
DL700 is offline
post #4 of 19 Old 05-05-2011, 02:01 PM
Wondering what the XX battery weighs? Is that alot more cranking amps?
post #5 of 19 Old 05-05-2011, 02:05 PM Thread Starter
DL700's Avatar
the 8 cell is 240 cca the 12 cell is 360 cca///
we use the 8 cell in our drag bikes and it cranks them over very fast, but i figure the 12 cell will leave no question on starting power even on the hondas small starter
DL700 is offline
post #6 of 19 Old 05-05-2011, 02:09 PM Thread Starter
DL700's Avatar
i think the xx battery is almost 8 lbs.. maybe someone can confirm weight
DL700 is offline
post #7 of 19 Old 05-05-2011, 02:29 PM
Jake777's Avatar
I'll bite... What kind of price are we looking at? Only mods I have are EHS big 3, would it be ok for that?
Jake777 is offline
post #8 of 19 Old 05-05-2011, 02:50 PM
CV4 also makes light weight batteries with more cranking amps, they go for a little over 200 dollars,and think they weigh less than 2 lbs. , it was in dirt wheels mag.
post #9 of 19 Old 05-05-2011, 02:54 PM
08700xx's Avatar
They are more than any of those ebay batteries but IMO worth it. I got to see how easy they cranked over HDD's big bore raptors and the weight savings over a stock battery so I ordered one.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #10 of 19 Old 05-05-2011, 03:22 PM
How long do they last? Durability? I realize you may not know for people that are in the cold for half the year, but what if you don't ride your quad for a while, they still tender friendly?
