Best air intake set up? - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 75 Old 05-10-2011, 04:35 PM
08700xx's Avatar
(DL700)
Jody (Boost Addict)
08700xx is offline
post #12 of 75 Old 05-11-2011, 08:53 AM
Does anyone worry about the crankcase breather not touching the filter with the k&n installed? I worry about dust going down the breather and into the engine.
post #13 of 75 Old 05-11-2011, 09:13 AM
boost addict's Avatar
The crankcase has postive pressure(blows out), so no dust can get in. Look at my pic, you will see oil on the k&n filter from the high compression piston(13:1) i am running.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #14 of 75 Old 05-11-2011, 03:08 PM
Yeah I knew it was blowing the air but I was thinking about taking a piece of my old foam filter and putting it inside the breather tube for peace of mind.
post #15 of 75 Old 05-12-2011, 10:01 AM
WiZkY's Avatar
you need controler to run without lid???
WiZkY is offline
post #16 of 75 Old 05-12-2011, 10:33 AM
mustangGH's Avatar
i run the modquad filter setup with the creek crossings and the xc racing we do here i pretty much have to run a lid of some kind
man that hole was deeper than it looked .......
dang jeff what are you adn the grizz doin upside down in the lake ???
08 trx700xx
Pro armor skid plates
Gbc x-rex 23x7x10 on dwt rokout rims
Maxxis Razr 22x10x11 on OMF 11" beadlock rims (whoot whoot) love em
Pro armor fatpeg nerf bars
Pro armor XC bumper
TAG bars
HID headlight conversion
fox floatx evol fronts
fox podium x rears
mustangGH is offline
post #17 of 75 Old 05-12-2011, 01:23 PM
TRX700XX's Avatar
Go to advanced auto parts, get the 4 1/2 universal fit K&N filter. Then install it using factory clamp, the end of the K&N will slide into the factory induction tube. Then throw a EHS Lid on it and ur set. BTW the filter is 35 dollars here! cheap fix
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #18 of 75 Old 05-12-2011, 01:26 PM
Nah you don't need a controller
post #19 of 75 Old 05-12-2011, 03:30 PM
x 2
Ed @
Chris & Mike
post #20 of 75 Old 07-06-2011, 03:46 PM
What length 4.5" universal K&N filter do you suggest, there seems to be several lengths. Do you know the K&N part number?
Also in another post someone noted that their EHS lid still allowed some dust into the air box. Is that normal? The trails I ride in GA and FL are very dusty.
2009 700XX Black - 13T, PRM Desert II + Side Bars (black), L8ton 9/16, Power Form Pro complete skids, K&N, EHS Big 3
hipowernut is offline
