Carb Conversion ....start to finish - Club700XX - Honda TRX700XX Forum
post #1 of 71 Old 05-10-2011, 05:07 PM Thread Starter
DL700's Avatar
So were going to convert Mike's 700xx to carb
First we will get a new baseline run with a few additional canges and try a new cam profile in it. I will post up those results when that gets done as our final baseline.
The goal of the project is to increase Hp and tq and give the engine more air volume and velocity along with good atomisation, firing it all off with increased spark energy, RPM and control. Estimated redline will be 9300. Estimated weight savings is 15 lbs.
Here are them components were starting with
48mm Lectron carb with billet bowl,Choke, and power jet
MSD single cyl ignition #4217
MSD coil
the flywheel will be modified
a new throttle box will be used
Fuel pump and lines removed
Throttle body, sensors and ecu removed
Wire harness modified
DL700 is offline
post #2 of 71 Old 05-10-2011, 05:24 PM
boost addict's Avatar
Mike's XX is going to be a beast! I take everything back i said about the carb lol.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 71 Old 05-10-2011, 05:26 PM Thread Starter
DL700's Avatar
Its a beauty...
we will be using an intake tube off a diffferent model bike though if we remove the RED velocity ring on the carb we can still use the oem unit
DL700 is offline
post #4 of 71 Old 05-10-2011, 05:27 PM
thats cool not my cup of tea but cool non the less, be curious to see what it does
EHSRACING is offline
post #5 of 71 Old 05-10-2011, 05:35 PM Thread Starter
DL700's Avatar
the factory plastics and tank will all remain making it an easy swap, weve even found the bikes start much quicker with a properly tuned carb, hopin for the same result with the xx
DL700 is offline
post #6 of 71 Old 05-10-2011, 05:37 PM Thread Starter
DL700's Avatar
comparison with the 48 carb and HDD +3 mm throttle body
DL700 is offline
post #7 of 71 Old 05-10-2011, 07:00 PM
08700xx's Avatar
Looks sick. I can't wait to get started.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #8 of 71 Old 05-10-2011, 07:24 PM
You are gonna need a fast pace truck to keep fuel in that beast when it is done. Better be careful or you'll suck your seat right into the airbox!
post #9 of 71 Old 05-10-2011, 08:16 PM
Lighter with mo powa!!!
post #10 of 71 Old 05-10-2011, 09:06 PM
Anxious to see the results. What the total on these parts?
