Valve adj and oil change Complete - Club700XX - Honda TRX700XX Forum
post #1 of 2 Old 05-11-2011, 02:33 PM Thread Starter
Hello to all trx700xx owners. Just purchased an 08 with about a year and a half of use. Rear tires need to be replaced, other than that is in fine condition. Just changed the oil with factory Honda synthetic 10/30 and oil filter. Very EZ service. I also adjusted the valves today, also very EZ, although it did take about an hour to do the process. A few things I noticed about the 700: Rear park brake needs attention (not working), No grease zerks on the suspension (why) Other than those two items seems to be a well built Quad. I also installed an hour meter to keep track of future sevrices. With out a odomiter or hour meter how would anyone know when to service. So far I like the 700. First ride will be Saturday!!!
Powerwon is offline
post #2 of 2 Old 05-11-2011, 05:50 PM
You look after it , it will look after you. Keep the fresh oil and filters up. You should have no problems.
