Barkers pipe question. - Club700XX - Honda TRX700XX Forum
post #1 of 63 Old 05-12-2011, 04:25 PM Thread Starter
Background..... NONE
Header bolts up to engine.... CHECK!
My question is, do I really just slide the 2 pipes together? Shouldn't I clamp them together or something? Just seems like it would leak where they connect?
Sorry for the n00b question.
fhibbs12 is offline
post #2 of 63 Old 05-12-2011, 04:49 PM
boost addict's Avatar
You should be fine, i think the barkers takes two to spring at the connection also.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 63 Old 05-12-2011, 04:52 PM Thread Starter
Yup just seen the spot for the spring.
Just seems weird like I should have something else to seal it.
fhibbs12 is offline
post #4 of 63 Old 05-12-2011, 04:58 PM
The Sparks exhaust is so tight there is no need for the springs.
Ed @
Chris & Mike
post #5 of 63 Old 05-12-2011, 06:16 PM
no gasket or clamp its a tight fit they wont leak, 1 spring also
EHSRACING is offline
post #6 of 63 Old 05-12-2011, 06:21 PM
Mine don't leak man! Your good
post #7 of 63 Old 05-12-2011, 06:28 PM
The Barkers uses a exhaust header gasket, unlike the Sparks. The flange is half as thick Sparks, that uses the longer 450r exhaust bolts. I like both exhaust, but the Sparks is built alot stronger/ better
I won't even get into the repacking of the Barkers muffler lol.
Ed @
Chris & Mike
post #8 of 63 Old 05-12-2011, 08:33 PM Thread Starter
Got the big 3 + uni in finally. It was storming so I just fired it up and reved it 3 or 4 short times.
I was in a closed garage..... I could see smoke coming from it which I didn't notice before and even when I shut her off it billowed out slowly for a few seconds. Also it was scalding to touch near the header just after about 15 seconds....
Normal?
fhibbs12 is offline
post #9 of 63 Old 05-12-2011, 09:03 PM
What problems did you run into with the Barkers boost? I have the Barkers on my sled and XX. I give that exhaust an absolute beating and I haven't had a single problem. I think its a great exhaust and puts down some awesome power!
post #10 of 63 Old 05-12-2011, 09:06 PM
or use high temp orange rtv...
-uni
-primary drive 13t
-pclll
-soon to have a cp 11:1
99 ford f-250 ccsb 7.3
-skyjacker 6'' lift
- 315-75r16 pro comp xtarrain
-sct 100hp tune
-straight pipe with 4'' dp
06 pos hyundia tuscon
-dont buy one there junk
live to ride and ride to live
