Sparkplug color - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 05-13-2011, 10:52 AM Thread Starter
Sparkplug color
Hey guys.
I have been riding with the big three for a month or so and i havent thought of checking the sparkplugg untill now. What should the color of the sparkplugg look like? Is this ok, and what about the exhaust isnt there a little bit to much of soot? I have the quiet core in and the settings of the efi is just like EHS recommend.
Thanks in advance.
Darson is offline
post #2 of 8 Old 05-13-2011, 11:46 AM
09RappySE's Avatar
Quoted: 16 Post(s)
You are rich...it should be like a brown paper bag color...I have seen worse.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #3 of 8 Old 05-13-2011, 12:44 PM
Your spark plug is the best indicator to see if you're lean or rich. Your exhaust tip isn't. You need to put in a NEW plug, run it a bit and then check color. Paper bag brown is what you want... NOT white (lean) or black(ish) (rich). You can lean out a bit by going down .5 on your green, yellow and red settings... I do this all the time when I ride at altitude... on the side of the trail in less than 5 min.
post #4 of 8 Old 05-13-2011, 02:07 PM Thread Starter
Thanks for your help, i am gonna buy me a new sparkplug and adjust the settings and see if that helps.
Darson is offline
post #5 of 8 Old 05-13-2011, 05:40 PM
Make sure to do the plug read correctly, you can research on line. I warm mine up a bit with the old plug. Put in the new plug. Take off and wind it out. Clutch it and kill it at WOT. Check the plug, should be a fuzzy tan. You can do the same at other throttle positions as well if you are concerned about midrange too. Use a new plug every read. You can use them later, but it is best to have a clean slate for each read.
The exhaust isn't a real good indicator, but black is way better than clean. If you are clean then you can stand to be richer, but you can't really tell if you are too rich by this unless it is very obvious. Mine is black, the plug looks just like I like it, it runs great and way cooler than stock.
post #6 of 8 Old 05-13-2011, 06:00 PM
Sorry for hijacking the thread.
Could anyone help me out with this one.
This was used at last dirt oval. Alot of idle when queuing then flat out when racing.
The engine was warmed up to the point of frying.
My plug has been the same for the last 12 months no matter what I race.
post #7 of 8 Old 05-13-2011, 06:03 PM
boost addict's Avatar
Attachment 3134
The fuel injector only sprays from one side. Looks good to me.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #8 of 8 Old 05-13-2011, 06:15 PM
Cheers Buddy. I have been waiting for the motor to lock up and throw me into a tree.
