To Rich To Lean? - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 05-15-2011, 11:42 AM Thread Starter
To Rich To Lean?
Got the big 3/Uni.
Header was glowing all the way up near the heat shield. Here is a pic of the plug. It was from casual trail riding 2-3 gear mainly. About an hour.
Front side
Back side
Yes that is the same plug. One side was WAY darker than the other.
fhibbs12 is offline
post #2 of 19 Old 05-15-2011, 01:15 PM
Is that the OEM plug or that fancy racing plug?
post #3 of 19 Old 05-15-2011, 01:34 PM Thread Starter
its that laser plat one.....
I think.. lol
fhibbs12 is offline
post #4 of 19 Old 05-15-2011, 02:01 PM
boost addict's Avatar
It's running rich. The fuel injector only sprays from one side. The darker side is facing the throttle body/ fuel injector.
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #5 of 19 Old 05-15-2011, 02:22 PM Thread Starter
Guess I need to figure out how to adjust the programmer then.
fhibbs12 is offline
post #6 of 19 Old 05-15-2011, 02:32 PM
08700xx's Avatar
Yeah its running rich. Most dobeck programmers are set to run a little rich to be on the safe side.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #7 of 19 Old 05-15-2011, 06:46 PM
Are you noticing it stumbling and loading up? Careful where you remove fuel when you don't know where you are rich or lean.
post #8 of 19 Old 05-15-2011, 06:51 PM Thread Starter
TBH it felt amazing riding it.
Granted I havent road it since last summer then installed everything.
But the power throughout the entire throttle range felt way better, just loud as hell, and those plugs seem to improve responce a ton.
Im thinkin Ill buy 3 more plugs this week and go do the old 1/4 throttle, 1/2 throttle, and full throttle thing and compare them.
fhibbs12 is offline
post #9 of 19 Old 05-15-2011, 07:12 PM
I think.. lol
Will that plug work with all stock, but a uni? And will it be a improvement or have any disadvantages?
post #10 of 19 Old 05-15-2011, 07:47 PM Thread Starter
I *think* it just mainly runs a little hotter but greatly increases throttle response.
Don't quote me on it though
fhibbs12 is offline
