Fuel Delivery - Club700XX - Honda TRX700XX Forum
post #1 of 24 Old 05-18-2011, 01:09 PM Thread Starter
GAZ69OK's Avatar
Fuel Delivery
I had some trouble with my trx700xx last weekend, so I will describe the situation and see if you all can help me troubleshoot.
I was trail-riding with a friend when the 700 acted as though it was not receiving fuel. I was moving along about 25mph when the engine sputtered, lost power and backfired, then returned to power and accelerated back to 25mph. All without letting off the throttle. It did this two more times, then died. I tried restarting and it fired for a sec or two then died again. I tried restarting it and it wouldn't fire. I tried and tired, and finally told my buddy to ride back to the truck for the tow rope.
While he was fetching the tow rope, I tried restarting the 700 without luck. I would turn engine run and key off and back on and try to start. No fire. I do recall NOT hearing the appropriate fuel pump pressurizing sound, like normal. The 2 seconds where it runs just after you turn the key on. It sounded as though it was attempting to pressurize but not completing. In other words, the sound was not normal and not for the normal duration.
I started looking for any loose connections, fuel leaks, or any other problem indicators. The fuel valve was in the ON position, but I turned it to off and then to on, and then to off and then to res. With the fuel valve in the res position I tried starting the 700 and it fired. At the time, I thought I may have had the fuel valve in the off position and I just ran the fuel out of the pump/lines. But after thinking about it, the valve was in the on position during the ride. We had been riding for a couple hours before this happened, so I don't think the valve had anything to do with it.
About 30 min before this happened I flipped my 700 over onto it's roof/seat. I turn the quad over, moved the engine run to stop then back to run, and the key to off and on. It wouldn't start until I did these things. I am assuming that is due to the bank angle sensor? Anyway, from the time I flipped it and restarted it until the fuel delivery problem was about 30min, and during that time I was jumping the 700. Nothing worth mentioning, just first gear jumping, turn around, wheelie off a bank, turn around and jump the bank, repeat.
When the quad died, it was around 25mph trail riding. I havn't really had a chance to mess with the 700 since i got it back to the trucks and loaded it up on the trailer. This is concerning, but I am not exactly sure how to handle the problem. (If it still a problem) The 700 fired right up after a wash and did fine on the drive from trailer to garage. I turn it off and on a couple of time and listened to the fuel pump and each time it primed like it was supposed to (or at least sounded like it).
I am guessing it is a problem with the fuel pump or the bank angle sensor. I plan to check the power input/ground line for the bank angle sensor with a voltage meter. Maybe inspect the fuel pump relay? Sub Fuel Tank/Fuel Pump inspection?
My 700 was purchased new from dealer in June 2010. I purchased it from the original owner. He says the factory warranty is still good for one year. I am not quite sure how that would work, since I am not the original owner, but should I take the quad in to a Honda dealer and let them work on it? Would my problem be covered?
Looking for suggestions. Thanks.
'08 TRX700XX List 'O Mods:
13t Drive
ASV Shorty Lever(s)
MQ Brake Block
Honda Racing Front Bumper
Alba Pro Elite Nerfs (Chrome)
J-n-J Full Skids
Uni Filter
CCP Steering Stabilizer
Streamline SS Brake Lines
Easton EXP M99 53/RM Mid Bars
MotoGrip Black Skulls
Offensive Fender Warning Tags
Black Shock Covers
FST Radiator Guard
Relocated Indicator Lights
Maier Top Cover
Tusk Gas Cap
GAZ69OK is offline
post #2 of 24 Old 05-18-2011, 03:43 PM
Is it just possible it was time to flip to reserve?
post #3 of 24 Old 05-18-2011, 03:55 PM
Rith's Avatar
That was my question
When I run mine out of gas it does the exact same thing. Kind of sputters and acts weird, then dies. Sometimes it will start, then dies again. Switch to reserve and its back to thumping. I'd fill it up and if it runs fine, good chance that was it
Also remember you can still see gas in the bottom of the tank when its time to switch to reserve because of however the reserve works. Just warning ya, cause I thought I had a problem the first time I did that
08' TRX700xx - Red n' Black
Big Gun EVO r Exhaust
00' CR250rintintin
Rith is offline
post #4 of 24 Old 05-18-2011, 05:31 PM
It sounds to me you were just low on fuel. Sounds about how mine runs when its time to switch to reserve
post #5 of 24 Old 05-18-2011, 06:02 PM
08700xx's Avatar
+ 1
(DL700)
Jody (Boost Addict)
08700xx is offline
post #6 of 24 Old 05-18-2011, 06:20 PM
MizuriDirt's Avatar
If I remeber correctly didn't they have an issue with dealers putting on the petcock wrong for the fuel switch?? That may be an issue too and you ran it out of fuel.
MizuriDirt is offline
post #7 of 24 Old 05-18-2011, 07:50 PM
Tory trx's Avatar
This happened to mine last weekend but I got her soaked and then it did it. Just died on the trail at about 30 and stalled. It fired up after a couple of minutes but was backfiring. Could it had gotten wet?
Tory trx is offline
post #8 of 24 Old 05-18-2011, 08:02 PM
scrawny's Avatar
when you are out of gas you have to flip to reserve, thats why its there ;)
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
post #9 of 24 Old 05-18-2011, 08:34 PM
boost addict's Avatar
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #10 of 24 Old 05-18-2011, 09:43 PM
Should be easy to check if you haven't added any more fuel.
