Anybody else notice this? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 05-18-2011, 06:26 PM Thread Starter
Tory trx's Avatar
When I changed my oil today, the longer bolt holding the oil filter cover in place came out and looked to be covered in a milky substance kind of like oil and water mixed together. Not sure what to think of this. The oil itself looked fine. Anybody else witness this at all?
Tory trx is offline
post #2 of 7 Old 05-19-2011, 11:28 AM
sounds like you been running through those deep ass ohio mud holes too much!
post #3 of 7 Old 05-19-2011, 11:34 AM
Nope I haven't noticed that Tory. Have u been starting it for a few minutes to let the batteries charge? If so it may just be some condensation build up.
post #4 of 7 Old 05-19-2011, 05:34 PM
When I did my first oil change, I saw what looked to be engine pre-lube on the bolt. It's possible that this was done at the factory to keep the bolt from seizing.
sgip2000 is offline
post #5 of 7 Old 05-19-2011, 07:58 PM
Do you power/pressure wash youre xx ?
post #6 of 7 Old 05-19-2011, 08:02 PM Thread Starter
Tory trx's Avatar
No pressure washing just a hose with a nozzle. Weird thing is, its only on the longer bolt. No other has this on it. Im stumped.
Tory trx is offline
post #7 of 7 Old 05-20-2011, 12:17 PM
Tory trx,
If it was just a white powdery substance it is corrosion (possibly it mixed with the oil giving it a milky appearance). (The product of a steel bolt threaded into to an aluminum housing (an electrolytic process)). I like it myself because it holds the bolts firmly so I never over tighten them especially that long one. They make a loud pop when loosening them.
Additionally, if you had just cleaned the bike there could have been some water on the head of the bolt that mixed with the oil as you unscrewed it during the oil change. Just a few thoughts.
