TB voltage - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 05-25-2011, 06:35 AM Thread Starter
TB voltage
I'm offshore and can't get to mine, Could someone check TPS voltage at idle and WOT?
post #2 of 11 Old 05-25-2011, 06:54 AM
boost addict's Avatar
Idle .5 -.7 Wot 4.2-4.4
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #3 of 11 Old 05-25-2011, 07:14 AM Thread Starter
Thanks
post #4 of 11 Old 05-25-2011, 08:20 AM
No problem.
Ed @
Chris & Mike
post #5 of 11 Old 05-25-2011, 10:22 AM
idle is supposed to be around 0 volts i think wide open was in the 4.2 area dont remember i had to play with this a lot the other week. I know the the xx has a efi fault for low setting out of wack and max setting out as well. The tps sensor was the issue i had with the +3 TB i think it was just the sensor itself. But fyi when it gets bored it changes the low side setting and you have to recalibrate the ecu for it to be in spec
EHSRACING is offline
post #6 of 11 Old 05-25-2011, 11:40 AM Thread Starter
We had fits trying to get mine tuned, The hacked up butterfly plate didn't help either. I thought I remembered it being 0-5 volt but needed to make sure. Thanks
post #7 of 11 Old 05-29-2011, 09:19 AM
Brokenbones's Avatar
Mine is running at 2200rpm at idle with the +3 throttle, haven't look at it yet, can it be the iac calibration?
Brokenbones is offline
post #8 of 11 Old 05-29-2011, 09:52 AM Thread Starter
You'd need the vortex to adjust the iac, I had to unplug the iac to get a good idle.
post #9 of 11 Old 05-29-2011, 10:28 AM
Did you notice anything by unplugging the iac?
post #10 of 11 Old 05-29-2011, 10:36 AM Thread Starter
The correct idle speed and a flashing dash light
