Hard rock...bent wheel...huge problem? - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 05-25-2011, 06:54 PM Thread Starter
Question Hard rock...bent wheel...huge problem?
Ok, first off. I was climbing a slightly rough hill climb maybe mid range 3rd gear and I smacked a rock with my left rear wheel. I didn't realize at the time what i had done. When i came to a rest back at the bottom i noticed that the tire was flat and that the wheel was...flat as well lol. I bent the rim back to almost perfect with a 4lb shop hammer. It has a small wobble but nothing like the wobble my ass would have by going to the honda shop for a replacement ($285 replacement). So, after fixing the wheel I went back to riding the atv. I then noticed that it ran different. It's hard to explain but it felt like the throttle was jittery in 2nd gear from the mid to high rev. range. It was past due for an oil change so i changed the oil, cleaned the air filter and checked coolant. Now, it seems back to normal.
Question #1: Did i hit hard enough to bend my a-arms? After measuring they seem to be exactly the same on both sides but im still worried.
Question #2: Did i hit hard enough to do internal damage to my transmission/clutches?
Question #3: Could a past due oil change cause a slipping/stuttering effect? It felt more like a throttle response than it did slipping. It's hard to explain.
thanks to anyone who responds back.
chromexx is offline
post #2 of 11 Old 05-25-2011, 07:21 PM
Pinto's Avatar
I've done this a couple times. I think it's a mental thing. You're so worried about having messed up your beloved XX that you get paranoid and start thinking somethings wrong.
Pinto is offline
post #3 of 11 Old 05-25-2011, 08:35 PM
old oil can affect the clutch. Maybe that was it or maybe it's all in your head? I've smacked tons of rocks and bent every wheel on the bike at some point. It's never hurt anything else.
post #4 of 11 Old 05-25-2011, 10:59 PM Thread Starter
lol...you guys are probably right. I love my 700 and it bothers me that something may be wrong with it. I rode it around several times today on the new oil change and didn't feel anything other than normal. I tried various different rpm ranges through different gears and never felt or heard it again.
On a side note, i was thinking about buying the EHS big 3 kit. I just dunno if the power gains are worth the $750. If anyone has any feedback about that I'd greatly appreciate it. Thanks again.
chromexx is offline
post #5 of 11 Old 05-25-2011, 11:21 PM
92K1500's Avatar
It's all mental.
I hit a tree hard enough that I folded my lower A arm, bent my reinforced rim, bent my shock, and bent the frame.
Put a new a arm on it, fixed the shock and I raced it last weekend. It still rides fine to me. It pulls to the right a little but nothing big.
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #6 of 11 Old 05-26-2011, 07:49 AM
I think your bike is fine. I bent both back wheels at the same time in uwharrie national forest and once I replaced them everwything was good. The big 3 is definately worth the money. I have the Curtis sparks exhaust ehs programmer and intake and it makes a big difference.
post #7 of 11 Old 05-26-2011, 08:00 AM
Tory trx's Avatar
2nd this..... I am so nuts that when I clean the bike all up I feel like it rides better than when it was dirty.
Tory trx is offline
post #8 of 11 Old 05-26-2011, 08:12 AM
Pinto's Avatar
x2^
Pinto is offline
post #9 of 11 Old 05-26-2011, 09:57 AM
GAZ69OK's Avatar
+1
'08 TRX700XX List 'O Mods:
13t Drive
ASV Shorty Lever(s)
MQ Brake Block
Honda Racing Front Bumper
Alba Pro Elite Nerfs (Chrome)
J-n-J Full Skids
Uni Filter
CCP Steering Stabilizer
Streamline SS Brake Lines
Easton EXP M99 53/RM Mid Bars
MotoGrip Black Skulls
Offensive Fender Warning Tags
Black Shock Covers
FST Radiator Guard
Relocated Indicator Lights
Maier Top Cover
Tusk Gas Cap
GAZ69OK is offline
post #10 of 11 Old 05-26-2011, 10:03 PM Thread Starter
hahaha it really does seem to run better when it's clean...it must be that mental thing you guys keep talking about lmao...I appreciate all the responses and now I feel a lot better about my baby being ok
chromexx is offline
