Engine calculations - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 05-27-2011, 06:58 PM Thread Starter
Engine calculations
I am looking for 2 calculations .
The first is engine bore and stroke to engine cc's. I tried my own version and came to 745cc. I think I may of got this wrong.
The second is a calculation that calculates engine rpm to rear wheel rpm. It's on here somewhere but I cannot find it. it goes through all the gear ratios.
post #2 of 5 Old 05-27-2011, 07:41 PM
CCs should be Area of Bore (A)=Pi*R*R R=radius in cm. Then take (A)*stroke(in cm). Pretty much the volume of a cylinder equation.
post #3 of 5 Old 05-28-2011, 12:15 AM
OzLinc's Avatar
Remember Bore is the full with of the cylinder but in calculating volume you need the radius which is half the bore.
bore is 102mm so. The the formula is Pi x 51 x 51 x 84
I use this calculator......you may need to drop a few numbers in there for the XX but it works.
OzLinc is offline
post #4 of 5 Old 05-28-2011, 09:35 AM
ein
ein's Avatar
Quoted: 4 Post(s)
http://nvmyz28.com/quads/displacement.html
Try this
Removed reverse rev limiter
Ds450 shock swap
EHS fuel programmer
Big Gun EVO R slip on
ein is offline
post #5 of 5 Old 05-28-2011, 12:05 PM Thread Starter
Cheers Guys , I was off abit . Its 753cc +3 bore and +3 stroke.
