56 Hp - Club700XX - Honda TRX700XX Forum
post #1 of 53 Old 03-04-2009, 07:15 PM Thread Starter
wayne matlock's Avatar
56 Hp
We just got done on the dyno and we were able to get 56 HP at the rear wheels and 38 pounds of torque this number is a little low because we used maxxis 22' tires. This is with the stock piston and pump gas just head work , throttle body and cam.
wayne matlock is offline
post #2 of 53 Old 03-04-2009, 09:05 PM
Got a dyno sheet? 56hp is pretty damn good! What was the air/fuel at?
post #3 of 53 Old 03-04-2009, 09:21 PM
Would you mind going a little further in detail? I understand you have races to win, but there are a lot of guys here looking to pull numbers like that with some simple mods like that.
post #4 of 53 Old 03-05-2009, 06:58 AM
Still using the XR cam? what stage?
post #5 of 53 Old 03-05-2009, 12:28 PM
vfm2010's Avatar
Details, Wayne, Details....Please!
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #6 of 53 Old 03-06-2009, 11:07 PM Thread Starter
No we are using a Web cam the XR650 cam dose not work in the 700 it will work for a short time but after further testing we destroyed a top end when we opened it up we found that the decomp was opening the valve at the wrong time so we sent one up to Web cams and they made us one for the 700. It hit 88.7 MPH in the dirt and was hitting the Rev limiter so it needs a taller gear. As far as more info goes I can only say so much because I am developing thees kits for alba. But if you call up Matt @ Alba I sure he would fill you in. One thing I can say is that is the fastest quad that I have ever ridden.
post #7 of 53 Old 03-07-2009, 12:02 AM
One word, EPIC!
post #8 of 53 Old 03-07-2009, 12:21 AM
fooleo's Avatar
Gonna have to get that taller gear and head up to El Mirage and run the "Flyin' Mile." I'd be interested in what the times would look like on the lake bed...
Rock on Wayne-O!!
FOOLEO - 260lbs of pure attitude
'08 700xx: 2-Bros Slip-On, Renthal Bars, DG Nerfs, UNI Filter, 13T sprocket, HMF Programmer, 22" RAZRs Front & Back, ASV Levers (Red)
fooleo is offline
post #9 of 53 Old 03-07-2009, 06:24 AM
While having my cams made we had looked at the xr cams, What we found was most companies do not grind them on any particular center line causing the potential problems you guys ran across with the decomp.
post #10 of 53 Old 03-08-2009, 10:52 AM
I have sent Matt at Alba an email regarding a release date and group pricing if we wanted to do a group buy.
Oh, and Wayne...what fuel programmer are you using?
