Quick fill system - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 05-31-2011, 07:36 PM Thread Starter
Quick fill system
Anybody tried fitting a quick fill system to the stock tank ?
post #2 of 7 Old 06-02-2011, 04:49 PM Thread Starter
Or if I fit a quick fill (dry break) system to the stock tank .Doing away with the stock cap and threads. Does the tank need to be vented somehow or does the dry break do this ?
post #3 of 7 Old 06-02-2011, 08:37 PM
When I had my stock tank, I had a quick fill valve from HDG Products. I worked flawlessly, and would recommend it for you. No more than 10 seconds to fill up!. I actually still run it, and have the option of running that valve or with an dry break adapter for a dry break tank. I don't think making the tank into a dry break is a good idea, but then again, if anybody can do it, you can. Yes, if you put a dry break, it has to be vented.
http://www.hdgproducts.com/quick_fill_valves.html
post #4 of 7 Old 06-03-2011, 02:39 PM
Yes, the tank will still need a vent. I think you could do it, would have to use the setup Clarke uses to seal the receiver to the tank:
http://www.clarkemfg.com/cart/index....roducts_id=135
The backing ring goes into the tank, then the cork gasket goes on the outside between the tank and receiver, tighten the bolts down to hold the receiver in place. I have a spare gasket laying around so I took it out to my stock tank, looks like it would work to me. Just need to use the gasket as a template to cut out the middle and drill the screw holes. Doesn't look to hard, as long as the mounting area on the tank is perfectly flat, which it looks like it is. I may just try it myself one of these days.
Although I bet the sytem Ceballos posted would probably work just as well, especially if you already have the 5 gallon jugs.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #5 of 7 Old 06-03-2011, 09:41 PM
Hey Doug, I was actually surprised how well that valve works! Great product for the money...
Lee, I have a brand new vent I'll send you if you want it.
post #6 of 7 Old 06-04-2011, 06:19 PM Thread Starter
I contacted Clarke awhile back and they said I needed 41/2" flat surface. The stock tank aint far off that .
Can you buy the tank vent as a kit ?
I am guessing this is not something, I want to build myself.
post #7 of 7 Old 06-06-2011, 10:58 PM
You can get the vent fitting from Clake also:
http://www.clarkemfg.com/cart/index....179lkp9tkhtjv1
I am sure they make a 90 degree one also, just found the straight one first. I then go to the local auto parts store and get a length of rubber vacuum hose, attach it to the vent fitting, then run it down to the bottom of the frame.
Doug
2005 TRX450R
1986 TRX250R
