removing stock sprocket??? - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 06-03-2011, 10:59 AM Thread Starter
WiZkY's Avatar
did we need a puller, or it's easy to pull it out?
WiZkY is offline
post #2 of 5 Old 06-03-2011, 11:16 AM
08700xx's Avatar
You don’t need a puller to remove the front sprocket... Its easy to remove.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #3 of 5 Old 06-03-2011, 11:38 AM Thread Starter
WiZkY's Avatar
Thanks
pass to 15t this weekend
WiZkY is offline
post #4 of 5 Old 06-03-2011, 11:42 AM
08700xx's Avatar
you’ll have to remove the case saver or grind it down a little so the 15t will fit.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #5 of 5 Old 06-03-2011, 04:13 PM Thread Starter
WiZkY's Avatar
it's done, I drind it a little bit!!!! around 1/16 to 1/8
WiZkY is offline
