13t sprocket - Club700XX - Honda TRX700XX Forum
post #1 of 59 Old 06-05-2011, 10:15 PM Thread Starter
XxX700XxX's Avatar
13t sprocket
i got a bone stock bike and was thinking about getting the 13t front sproket i do most my riding in the dunes drag racing or do alot of dirt road drag racing my question was will i lose alot of top end and will it make a big diffrence ont the bottom end? thanks
XxX700XxX is offline
post #2 of 59 Old 06-05-2011, 11:15 PM
NavyNut is offline
post #3 of 59 Old 06-05-2011, 11:44 PM Thread Starter
XxX700XxX's Avatar
ohh ok thanks navynut
post #4 of 59 Old 06-06-2011, 12:05 AM Thread Starter
XxX700XxX's Avatar
my main concern was if i could launch in second in the dunes at the drag strip i know with stock tires i could with the 14t but they just spun outa the hole now i got 22 11 10 10 paddles sand devils paddles and dont know how theyll launch with a 14t while in 2nd should i go with a 13t? we drag race between 600-1500 feet????? my bike is bone stock
post #5 of 59 Old 06-06-2011, 12:24 AM
It's $25 for the sprocket, Sometimes the best answer is trial and error. I'd put this one in that category.
post #6 of 59 Old 06-06-2011, 03:11 AM
TRX700XX's Avatar
sprockets are 7.99 i believe on rockymountainatv.com
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #7 of 59 Old 06-06-2011, 07:12 AM
92K1500's Avatar
Yeah $25 is way high for it. They are like $17 shipped off ebay.
And I'd get it anyways. I'm tempted to get a 15 as well just because I can. That way I can gear it for whatever I'm doing.
I know on dirt roads/long straights the 13t isn't near enough. You have to force yourself to slow down so you aren't cruising at redline.
2008 Honda TRX700XX
AC Racing MX Nerf Bars.
PRM Desert Grab Bar.
92K1500 is offline
post #8 of 59 Old 06-06-2011, 08:45 AM
TRX700XX's Avatar
We ride endless dirt roads around here and i love my 15, if i could put a 16 on it i probably would! but i purchased a 13t and 15t at the same to to play with my gearing
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #9 of 59 Old 06-06-2011, 10:49 AM
GAZ69OK's Avatar
So the 13t will be best for dirt drags?
I will take my 14t should I need to change, but removing and reinstalling the J n J skid isn't pleasant; with the weather striping I had to use to keep it from rattling. So I would like to have the correct sprocket on before the races.
'08 TRX700XX List 'O Mods:
13t Drive
ASV Shorty Lever(s)
MQ Brake Block
Honda Racing Front Bumper
Alba Pro Elite Nerfs (Chrome)
J-n-J Full Skids
Uni Filter
CCP Steering Stabilizer
Streamline SS Brake Lines
Easton EXP M99 53/RM Mid Bars
MotoGrip Black Skulls
Offensive Fender Warning Tags
Black Shock Covers
FST Radiator Guard
Relocated Indicator Lights
Maier Top Cover
Tusk Gas Cap
GAZ69OK is offline
post #10 of 59 Old 06-06-2011, 10:56 AM
92K1500's Avatar
The 13t would give you more low end torque and SHOULD (I'm not positive here) give you a little more off the line acceleration. But if you need to go over ~65-68mph you should run the 14t. I think redline on the 13t is around 73mph
2008 Honda TRX700XX
92K1500 is offline
