200kph!!! - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 06-19-2011, 01:13 PM Thread Starter
200kph!!!
just went out with my newly installed trail tech unit and i can hit 200kph no sweat so i think you guys need to check your gearing properly.....
from another post, are the below ok? im running stock tires....
Tire size with the stock front tires I used 1632. Temp settings - 220 F yellow warning 230 F red warning (Honda manual says the fan turns on at 216 F). Shift points - 4000 rpm yellow warning - 5000 red warning
tchui is offline
post #2 of 10 Old 06-19-2011, 03:50 PM
scameron92's Avatar
Not really sure thats possible considering thats about 124 mph.
2008 trx700xx
1992 250x (sons)
2005 crf230
2005 LTZ250 (sons)
scameron92 is offline
post #3 of 10 Old 06-19-2011, 05:35 PM
Heika's Avatar
think it works with those settings.
i do bout 110kph 13tooth sprocket.
how did u install the tach meter?
Honda Trx 700xx Black And Grey
Mods:
L8ton Sway Bar 11/16"
Alba Pro Elite Bumper
Alba Pro Elite Nerfbars
J n J Skidplates
Supersprox Front Sprocket 13 Tooth
Reverse Rev Limiter Removed
Trailtech Vapor
Powermadd Black And Chrome
Hidlights-5000K
Heika is offline
post #4 of 10 Old 06-19-2011, 07:59 PM
My XX goes 250kph! :P
post #5 of 10 Old 06-19-2011, 09:40 PM
lol u got the tire size settings wrong. get a gps and u can fine tune the settings.
08 Honda 700xx
Installed
Britalican is offline
post #6 of 10 Old 06-20-2011, 05:25 AM Thread Starter
heika, i didnt get the one with the tach, i got the one with the remote/rally setting and am expecting great service from it, we always get lost in races and doing away with the additional math involved (compensating for the 'lost' Km's) will be very welcome.
ill put in those settings and go from there. thanks
tchui is offline
post #7 of 10 Old 06-20-2011, 09:32 PM
Send a message via MSN to Gravyking
138kmh on my GPS with 14T sprocket!
Gravyking is offline
post #8 of 10 Old 06-21-2011, 02:26 PM
Heika's Avatar
its called the tacho meter shows the RPM
Mods:
J n J Skidplates
Trailtech Vapor
Hidlights-5000K
Heika is offline
post #9 of 10 Old 06-25-2011, 02:14 PM
The best way to set your speed/distance is to measure wheel circumference using the rolling method. It is critical to get this measurement spot on. Even a little off will end up making a big difference. Trail Tech instructions will outline how to do this.
post #10 of 10 Old 06-25-2011, 02:18 PM Thread Starter
roadkill i agree with you fully, just cant find my damn tape measure.....!!!
tchui is offline
