Air Filters - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 08-19-2008, 10:28 PM Thread Starter
happy Air Filters
Are you guys still rolling stock?
If not, what did you get and why?
How much did you pay?
What do you think?
post #2 of 13 Old 08-20-2008, 01:38 AM
Still stock here, wanted to check and see what the hot setup was around here......
any suggestions?
XC_XX is offline
post #3 of 13 Old 08-20-2008, 01:47 AM
xx-rated's Avatar
Still running stock, I figure I'll swap the filter when I get my pipe and controller. I always liked K&N, but I think I'm gonna run a Uni or Twin Air this time. All the research I have done has shown foam filters to be better for dusty conditions.
xx-rated is offline
post #4 of 13 Old 08-22-2008, 09:41 AM Thread Starter
I'm still running stock too, although I have cleaned mine once.
I couldn't get the stock screw off so I ended up forcing the filter out. Man was it a booger to get out!
Also, it's worth mentioning that the steal cage thingy that goes inside of the filter is quite heavy duty, I imagine the ones for aftermarket filters will be lighter and less restrictive.
post #5 of 13 Old 09-03-2008, 03:56 AM
K&N!!!
YSW_Racing is offline
post #6 of 13 Old 09-03-2008, 08:58 PM
msg harmon's Avatar
Still running stock and do not plan on changing it. K&N is nice for air flow but dirt also goes thru the filter right into the engine. Then its time to redo the valves. Sorry but stock is best.
msg harmon is offline
post #7 of 13 Old 09-03-2008, 09:02 PM
KTM265's Avatar
Send a message via Yahoo to KTM265
laughing
PSW... Here is an air filter designed for you. One for your mouth and since this is the Interent...
KTM265 is offline
post #8 of 13 Old 09-03-2008, 09:09 PM
msg harmon's Avatar
Well its just that I am a Real technician and have seen the results of a K&N filter. Just prefer the foam/oil. Check your oil next time you ride in the dust just after changing it. It will have allot of dirt from the air your bike is breathing. Try it some time thats all. The only reason oil gets dirty is because of the air intake.
post #9 of 13 Old 09-04-2008, 01:36 AM
ya but if you use a prefilter on a K&N it helps ALOT.
post #10 of 13 Old 09-04-2008, 12:54 PM
xx-rated's Avatar
Like I said, if you ride a lot in dusty conditions, foam is the way to go. Uni has a filter available now, the part number is #NU-4143ST. Since I have yet to clean my stock one, I dont know if you'll need a filter for the breather as well if you swap out the stocker, but I would think so.
xx-rated is offline
