Anyone try Cylinder Works big bore? - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 06-20-2011, 06:58 PM Thread Starter
http://www.cylinder-works.com/Produc...x?item_id=3341
CYLINDER WORKS 727CC BIG BORE
Aluminum cylinder with a nickel carbide coating designed with wider water jackets
Forged piston with a moly coating ( I don't know what brand, I sent an email to find out)
Rings
Clips
Wrist pin
Top End Gasket kit
105MM BORE
NO Machine work needed
Everything you need to bolt up and go
Anyone know anything about this, or have one?
08 Honda 700xx
Installed
Britalican is offline
post #2 of 10 Old 06-20-2011, 07:13 PM
its a namura piston and that kit they only offer stock compression 10:1
post #3 of 10 Old 06-20-2011, 08:02 PM Thread Starter
cool, thanks for the info.
08 Honda 700xx
Installed
post #4 of 10 Old 06-22-2011, 09:34 PM
Isn't stock compression 10.5:1
post #5 of 10 Old 06-23-2011, 12:02 AM Thread Starter
its 10.0:1
08 Honda 700xx
Installed
post #6 of 10 Old 06-24-2011, 06:05 PM
I thought it was a Vertex piston with the kit.
post #7 of 10 Old 06-24-2011, 08:03 PM
Is this a sleeved or bored kit?
post #8 of 10 Old 06-24-2011, 08:13 PM
pretty much every cylinder works kit i know of is bored nikalsid alum i think with a piston change this will be a good setup with a stroker you may want more skirt coverage but its hard to be them for cost wise on a kit
EHSRACING is offline
post #9 of 10 Old 06-24-2011, 08:41 PM
I agree, I paid that alone for my sleeve and install.
post #10 of 10 Old 06-24-2011, 10:23 PM
your right bax my mistake , was thinkin about another kit.
