Valve Adjustment numbers - Club700XX - Honda TRX700XX Forum
post #1 of 2 Old 07-02-2011, 03:08 PM Thread Starter
RaVxX's Avatar
Ok, so i searched the forums a bit, and looked at the manual, there is 2 numbers, which one do i go by ?
in: 0.15+0.02 mm (0.006+0.001 in)
ex: 0.20+0.02 mm (0.008+0.001 in)
The part i don't get is what number to go by and would a feeler gauge from Advanced auto work ?
Can someone explain the numbers ? like what the (+) is in there for ?
I would like to adjust them, but never messed with valves before, i think i can do it, but i just want to make sure i do it right the first time.
_______________________________________________
08 Red & Black 700XX
15T, Open Air Box w Uni, full HMF, PCIII, Kenda Kutters Front and 50lbs worth of Super Swamper Vampires in the back.
11 Can-Am Renegade 800R
HMF Slip on, ITP SS108 wheels w/ 27" Zillas, Stage 1 Elka's, ATV 4 Play Soft Bars.
RaVxX is offline
post #2 of 2 Old 07-02-2011, 03:39 PM
RaVxX,
Use the standard American feeler gauge measurements with the thousandths markings printed on them.
Intake 0.15mm is equal to 0.006 + 0.001 inches
Exhaust 0.20 mm is equal to 0.008 +0.001 inches.
It is just a conversion from Metric to SAE (Standard American Equivalent).
The + (plus) means you can have an additional 0.001of an inches without having the valves too loose. They don't give you a - (minus) because they don't want the valve too tight.
If they said "+ or -" you would be able to have that same 0.001 of an inch either thigter or looser.
