Programmer info needed for anyone that has added one! - Club700XX - Honda TRX700XX Forum
post #1 of 26 Old 07-08-2011, 07:46 PM Thread Starter
Question Programmer info needed for anyone that has added one!
Well I'm working on a turbo 700 right now, besides from trying to figure out if it's really necessary for an intercooler, I need to find out what's the best programmer out to tune with. I will have pictures up as soon as I figure out the intercooler situation. If anyone as any info on the programmers that are out right now and care to share their information about it, it would be much appreciated. Thanks.
NOLATRX700XX is offline
post #2 of 26 Old 07-08-2011, 08:02 PM
The Power Commander or Vortex ECU would be your best options and can do everything needed.
post #3 of 26 Old 07-08-2011, 08:06 PM Thread Starter
Is it self tunable or do you have to download different maps for it?
post #4 of 26 Old 07-08-2011, 08:49 PM
If you're going turbo you will need to have it tuned. I dont think there is any map out there for a turbo xx. Also, I would definitely run a intercooler.
post #5 of 26 Old 07-08-2011, 08:51 PM
traitor08's Avatar
It is self tuneable, the powercommander 5 has a seperate input for an add on sensor(probably good for boost). It also has capability of switching between 2 maps on the fly. And you can get a wideband 02 sensor and watch what it does on alaptop.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #6 of 26 Old 07-08-2011, 08:58 PM Thread Starter
Well there are to scenarios I'm playing with right now on where to mount it, if I can figure out a safe way to run the piping. But I'm also worried about water hitting it, as hot as it gets I wouldn't want to crack the exhaust housing. So I'm playing around with it right now. But I'm trying to figure out if there are self tunable ones
post #7 of 26 Old 07-08-2011, 09:03 PM Thread Starter
Well I ran across a dynojet one that has an O2 sensor that plugs in and adjusts itself to the proper A/F ratio, but I don't know how well is it. But I'm going to try and read more up on that one I'm just basically getting testimonies on them.
post #8 of 26 Old 07-08-2011, 09:04 PM
The turbine housing will not crack. I'm not saying go submerge it red hot in water but you'll be fine. I've seen red hot turbo headers dumped in water due to impatience and stupidity. That header didn't crack but is also had really good welds. A solid cast turbine housing should be fine.
post #9 of 26 Old 07-08-2011, 09:14 PM Thread Starter
Well I'm leaning more towards where the air box use to be it's the safest place for it. No muffler just straight pipe out the back and piping can be squeezed between the motor and frame for the intercooler. Oh the turbo choice is between a t15 and a t25.
post #10 of 26 Old 07-08-2011, 09:28 PM
traitor08's Avatar
I would really love to see this finished. I got some tractor weights you could put on front to keep it down....
MY RIDES
Tags
turbo
