Stock Baffles - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 07-12-2011, 08:00 PM Thread Starter
dewking's Avatar
Stock Baffles
Can you remove the stock baffles on a TRX700XX
Regards,
Dewking
dewking is offline
post #2 of 9 Old 07-18-2011, 10:57 PM
quadmonkey700xx's Avatar
if you mean the spark arrester then the answer is yes. btw it sounds like CRAP after you do
quadmonkey700xx is offline
post #3 of 9 Old 07-19-2011, 08:08 PM
traitor08's Avatar
3 small bolts on rear of pipe, and pull it out. 5 min later you'll be putting it back in, because it does sound like said above.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #4 of 9 Old 07-20-2011, 01:59 AM
Admin's Avatar
Where's the instructional how-to???
Admin is offline
post #5 of 9 Old 07-20-2011, 06:26 AM
lol post #3 says it all, not much more to it, unless you need size of bolts.
post #6 of 9 Old 07-20-2011, 09:12 AM
traitor08's Avatar
I believe 8mm bolts, turn somewhere around 8-10 complete turns to the left to remove bolts. Grab the outer "guard " for pipe and slide baffles out. Should be close to step by step.
MY RIDES
post #7 of 9 Old 07-20-2011, 11:24 AM
Yes, the 3 bolts are 8mm, and yes it will sound like crap... my farts sound better. But, you all forgot to advise using a bit of anti-seize on the bolt threads before you put your spark arrester back in... and you will as soon as you hear it without the sparky. The bolts DO have a tendency to seize because of exhaust heat.
post #8 of 9 Old 07-20-2011, 12:14 PM
Admin's Avatar
My point is, this forum is for posting HOW-TO's, not for asking questions. I don't see what's so hard to understand about that.
Moving to the proper forum..
Admin is offline
post #9 of 9 Old 07-20-2011, 06:55 PM
If you want to try it, make sure to go back and forth with the bolts when removing them if they get hard to turn. Like they said above they have a tendency to stick and they will twist off super easy.
The last baffle can be drilled and give you a straight shot from the tube on the front baffle. Never done it on a 700, but have on a 400EX. I did put the spark arrester back on though.
