question - Club700XX - Honda TRX700XX Forum
post #1 of 77 Old 07-27-2011, 10:37 AM Thread Starter
question
OKay I have a 08 700xx.. it has the power bomb header fmf pipe .. after market air filter and I have the fmf programmer but It got wet so gotta check with warranty.. I was wondering what would be the best bang for my buck.. I mean I don'twanna dump a grand right now .. so let's start with kinda cheap.. I'm new to the forums thanks everyone
softparade is offline
post #2 of 77 Old 07-27-2011, 11:36 AM
A cam would be great with what you have and be the biggest bang for the buck
post #3 of 77 Old 07-27-2011, 11:37 AM
EHS may be able to help you with the programmer if FMF doesn't warranty
post #4 of 77 Old 07-27-2011, 12:33 PM
08700xx's Avatar
Welcome to the Club If your not looking to spend a lot of money a Hot Cam would be a good option.
(DL700)
Jody (Boost Addict)
08700xx is offline
post #5 of 77 Old 07-27-2011, 02:03 PM Thread Starter
I plan on a big bore this winter.. how hard to put in a cam?
post #6 of 77 Old 07-27-2011, 02:04 PM Thread Starter
Oh I also bought a 13 tooth sprocket last night
post #7 of 77 Old 07-27-2011, 02:13 PM
08700xx's Avatar
you should do a lot of other things before you do a BB IMO. Its easy, the Hot Cams is just a drop in and like Smooth said you can call EHS and he can set up a progammer for your mods.
Where are you from?
(DL700)
Jody (Boost Addict)
08700xx is offline
post #8 of 77 Old 07-27-2011, 02:45 PM
A cam install is fairly easy, Nothing to complicated. If you or a buddy have done any motor work before you shouldn't have any trouble.
As 08700XX mentioned there are a few other upgrades that would help maximize your BB build. (Ported TB, Ported Head, Cam and a Fuel programmer) If you pay EHS to fix your dobek you could use it, If not you'll need a PowerCommander.
post #9 of 77 Old 07-27-2011, 02:51 PM Thread Starter
I've done tons of top ends and put a crank in a 08 big bear.. so I'm sure I could do it. JUSt wondering how hard. Which cam would ya'll suggest? . And about this ported tb.. what's that cost? And can my local machine shop do it? Or what would ya'll suggest..
post #10 of 77 Old 07-27-2011, 03:03 PM
08700xx's Avatar
I would call Daniel at HDD 951-743-6328 (DL700 on here) he can get you a +3 TB he may even have one in stock. Heres a link
https://www.club700xx.com/vb/showthread.php?t=6637
I would go with the Hot Cam 3 if you are trying to save money. If you are planning on going all out on your motor in the future you should buy parts now that will still work then so you may want to look at the Web Cams, they cost more and are not drop in cams but will give you a better gain when/if you do head work/BB in the future.
(DL700)
Jody (Boost Addict)
08700xx is offline
