Trail Tech Vapor Install - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 07-29-2011, 01:25 PM Thread Starter
mquez700xx's Avatar
For any one that has done this could you post up pictures of how you connected everything!!! The light to the Vapor does not turn off so i know i did somethign wrong. I know there is a thread for this already, but i need better pictures than what is already on there.
MODS ---
L8ton 9/16 sway bar
L8ton bumper
Tusck Hand Guards
EHS Big 3
Elka Stage 3 shocks
K&N Filter with outearwear
UNI Air Filter For dusty terains
Vapor computer
X Bar with vapor clamp
Spider Grip
TRX shock covers
Smoke headlight cover
Alba Racing Nerfs
Razs Tires
mquez700xx is offline
post #2 of 6 Old 07-29-2011, 11:03 PM
JBGILL06's Avatar
What did you connect the ground wire to?
2008 Honda TRX700XX
*Power Commander V
*Pro Design Air Filter
*Elka Stage One Shocks
*Pro Taper Evo Bars
*Trail Tech Big Bar Clamp
*MSR Clutch Perch
*Powermadd Handguards
*ODI Rogue Grips
*IMS 5gal Tank
*Pro Armor XC Bumper
*PRM Full Skid Plates
*Maxxis Razr II Tires
*ITP Aluminum Rims
2007 Honda Rincon GPScape
JBGILL06 is offline
post #3 of 6 Old 07-29-2011, 11:21 PM
blkcruzer's Avatar
The light usually turns off after 10 or 15 minutes of not moving, mine is wired right to the battery and always has power.
2008 TRX700XX Black/Red
Mods:
Trail Tech Vapor with Riser
ODI Rogue Grips
Pro Armour FatPeg Nerfs
PRM rear grab bar
PRM .190 full skid plate
Pro Design K&N Intake
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
DS450 front reservoir shocks
L8ton 11/16 Sway bar
blkcruzer is offline
post #4 of 6 Old 08-01-2011, 01:04 AM Thread Starter
mquez700xx's Avatar
i connected ground to the negative termenol on the battery but cruzer you are right it turns off after a while. there has to be a way to wire it up ware the light turns on when you turn the key???
MODS ---
L8ton 9/16 sway bar
L8ton bumper
Tusck Hand Guards
EHS Big 3
Elka Stage 3 shocks
Vapor computer
Spider Grip
TRX shock covers
Alba Racing Nerfs
Razs Tires
post #5 of 6 Old 08-01-2011, 01:09 AM Thread Starter
mquez700xx's Avatar
i also need to get a resister wire but cant find it on the Trail Tech website. if anybody has used one let me know ware you got it, thanks!!!
MODS ---
L8ton 9/16 sway bar
L8ton bumper
Tusck Hand Guards
EHS Big 3
Elka Stage 3 shocks
Vapor computer
Spider Grip
TRX shock covers
Alba Racing Nerfs
Razs Tires
post #6 of 6 Old 08-03-2011, 11:01 AM
blkcruzer's Avatar
The wire with the resistor built in comes from a raptor, I just called trail tech and told them the issues I was having and the guy sent one out for free.
Mods:
ODI Rogue Grips
PRM rear grab bar
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
