Stupid air filter screw!!! - Club700XX - Honda TRX700XX Forum
post #1 of 16 Old 07-31-2011, 01:51 PM Thread Starter
Why do the simplest tasks often become the most troublesome???
Ok, so I get my EHS controller installed and programmed - simple, easy, perfect.
Next, I go to install my new K&N air filter, which first requires removal of the factory air filter. Ok simple enough, I've only changed every air filter in every vehicle I've ever owned, should take less than 5 minutes, right?
Wrong! The stupud screw that secures the bracket at the back of the air filter seems welded on. Mind you this is a new 700XX with less than 20 hours. Of course Honda used a regular phillips screw that is now starting to get messed up cause it won't budge. I had even let some kroil seep in before I got started, but no luck.
Don't tell me some factory nim rod decided to use red locktite on that screw and now I may have to drill it out.
2009 700XX Black - 13T, PRM Desert II + Side Bars (black), L8ton 9/16, Power Form Pro complete skids, K&N, EHS Big 3
hipowernut is offline
post #2 of 16 Old 07-31-2011, 01:58 PM
aschuck's Avatar
Yes they use locktite,
Replace it with an allen head screw.
If you have a soldering iron, try to heat it up first.
aschuck is offline
post #3 of 16 Old 07-31-2011, 02:10 PM
Place your screwdriver in the head of the screw and then bump the screwdriver with a hammer to help jar it loose if that doesn't work its time to get a lefthanded drill bit.
post #4 of 16 Old 07-31-2011, 02:33 PM
traitor08's Avatar
I used a good set of vise grip pliers to get mine loose. Clamped it on the head and twisted.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #5 of 16 Old 07-31-2011, 03:17 PM
Rith's Avatar
I can't believe how many people I've read had problems with that screw. Mine came off really easy, and my buddies came off pretty easy too :-/
08' TRX700xx - Red n' Black
Big Gun EVO r Exhaust
00' CR250rintintin
Rith is offline
post #6 of 16 Old 07-31-2011, 03:27 PM Thread Starter
Drilled it out, finished K&N air filter install and topped it off with the EHS lid.
Next weekend it'll be my first oil change. I've already printed out Scuzz's install steps but I'm sure my Power Form Pro skid will be loads of fun when the oil starts coming out.
Me and my buddy are doing our first maintenance chores cause we're hittin the Ocala Nat'l Forest trails at the end of September with some friends from Kissimmee.
post #7 of 16 Old 07-31-2011, 04:54 PM
Mine was a chore to get off at the time also. I dont as mentioned, Tapped on it with a hammer and backed it out.
post #8 of 16 Old 07-31-2011, 07:36 PM
Mine was a PITA too. I replaced it with a 8mm bolt. Now i just use a wrench to get it off.
post #9 of 16 Old 07-31-2011, 09:20 PM
hipowernut,
Welcome to the club. I had to take mine to the shop to get the screw removed. The jerk/s at the factory did use red Loctite on the screw. The local technician had to drill out the screw. I was really upset and told Honda about it. They really didn't have any comment. The new screw has a hex head and is easily removed with a small socket. I think that part of the assembly was accomplished by an employee that was pi--ed or working his final day at the factory.
post #10 of 16 Old 07-31-2011, 10:54 PM
Queenz700XX's Avatar
i stripped the screw so i used a sawzall to cut out the plastic piece and the vibration from it broke the screw loose. i didnt need the screw for the k&n filter anyway
2008 TRX 700xx
PCV
FMF Powercore 4 full exhaust
K&N Intake
Modified Airbox
13t Front Sprocket
Billet Gas Cap
rear- 22x11x10 razr2
front- 22x7x10 razr2
ITP SS112 MACHINED RIMS
ALBA PRO ELITE NERFS
l8ton 11/16 sway bar
Queenz700XX is offline
