Now the seat?!? C'mon!!! - Club700XX - Honda TRX700XX Forum
post #1 of 19 Old 07-31-2011, 04:59 PM Thread Starter
Ever have one of those days? I finally get the EHS programmer/lid and the K&N filter installed and now I can't get the stupid seat back on!
I have tried 20 times but it won't go. I've had this trouble before but have always managed to get it on - till today!!!
2009 700XX Black - 13T, PRM Desert II + Side Bars (black), L8ton 9/16, Power Form Pro complete skids, K&N, EHS Big 3
hipowernut is offline
post #2 of 19 Old 07-31-2011, 05:52 PM
Admin will love you for this
post #3 of 19 Old 07-31-2011, 06:41 PM
Where did you fit the programmer ?
post #4 of 19 Old 07-31-2011, 07:52 PM Thread Starter
I mounted the programmer under the seat on the vertical sidewall, same place many others have mounted.
Oh - and I finally got the seat back on at attempt 25. I did several searches in these forums to find comments or tricks about seat installation but I couldn't find any.
Boy the thing runs great. I didn't install a pipe so I guess I'm at 2/3 of the big 3. I really don't want a loud pipe at this point, maybe later. EHS programmer was super easy to install and change settings.
post #5 of 19 Old 07-31-2011, 10:37 PM
hipowernut,
I wish I could find out who designed the seat attachment points. It had to be the same guy/gal that put the screw in the air clean hold-down bracket with Loctite. I have decided that barely starting the left side of the seat into the slot and pivoting it to the right side works about 20 to 30% of the time. The rest of the time I spew out colorful language. That works more often then not. When the machine is hot it is totally different then when it is cold. When cold it takes less effort. Gotta love that cheap plastic. Sorry, if I sound upset but there just some things about that machine that are really odd.
post #6 of 19 Old 07-31-2011, 10:39 PM
traitor08's Avatar
My seat goes on in about 5 seconds.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #7 of 19 Old 07-31-2011, 10:48 PM
CRAVEN7786's Avatar
I have never had a problem with my seat either.
CRAVEN7786 is offline
post #8 of 19 Old 08-01-2011, 10:35 AM
ive had a few different makes of quad and although i like the xx it must have the hardest seat in the world to go on...though it was just me...
elioquadsport is offline
post #9 of 19 Old 08-01-2011, 03:16 PM
TRX700XX's Avatar
I take the rear of the and press it slightly above my D*** and use both arms to press in on the very front points of the seat and do a slight "hump" motion then pull the latch and press down lol... its a way to make love and put the seat back on this babe! LMFAO
TEAM TORQUE RACING
2009 TRX700XX
TRX700XX is offline
post #10 of 19 Old 08-01-2011, 03:30 PM
JBGILL06's Avatar
Have you guys ever tried fitting the seats onto the Honda Utilities? My Rinconand and my dads Rancher are ridiculous.
2008 Honda TRX700XX
*Power Commander V
*Pro Design Air Filter
*Elka Stage One Shocks
*Pro Taper Evo Bars
*Trail Tech Big Bar Clamp
*MSR Clutch Perch
*Powermadd Handguards
*ODI Rogue Grips
*IMS 5gal Tank
*Pro Armor XC Bumper
*PRM Full Skid Plates
*Maxxis Razr II Tires
*ITP Aluminum Rims
2007 Honda Rincon GPScape
JBGILL06 is offline
