Velocity Filters and Dirt - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 03-12-2009, 03:31 PM Thread Starter
Guys,
I found an interesting set of pictures from another forum and thought I would share with you as far as Velocity Filters and dirt passing through them.
I'm sure that this isn't Velocity specific, and I don't have any information regarding the 700xx, but I thought I would share.
Also, I'm not bashing any brands here, but merely passing on the information. check your intake plenums:
post #2 of 12 Old 03-12-2009, 04:10 PM
xx-rated's Avatar
Gee, I feel so much better about my Velocity purchase now!!
xx-rated is offline
post #3 of 12 Old 03-12-2009, 06:25 PM Thread Starter
post #4 of 12 Old 03-12-2009, 07:24 PM
OzLinc's Avatar
Been down this road before.....
I will not use a paper and gause filters like the Velocity and K&N; they do have a slight advantage with flow but do not filter as well as the foam.
The other thing I don't like about the Velocity/K&N is that they do not have a inner frame like the foam because they are stiff enough to stay where they are without it. This is OK for a while but they do loose their stiffness and start to collapse in on themselves under load. This allows fine particles through and can also allow the filter material to break off and be sucked in to the engine........see pic below.
That thing that looks like someone has scraped a screwdriver accross it is off a Raptor that had a collapsing filter......its a Velocity.
OzLinc is offline
post #5 of 12 Old 03-13-2009, 06:41 AM
Upkeep is very important on these type's of filters to prevent this. I'll admit that they may not catch as much as a foam but these pics are of neglect and not poor filter design
post #6 of 12 Old 03-13-2009, 09:09 AM
TRX_Sixpac_700xx's Avatar
I'd have to agree with Smooth. It is not that hard to clean your filter before/after riding. I would understand that if you drive it everyday that it would get to be a hassle to clean it daily, but just like everything else if maintenance is kept up, you shouldn't have a problem like this.
TRX_Sixpac_700xx is offline
post #7 of 12 Old 03-13-2009, 09:16 AM Thread Starter
I have a foam UNI and clean it after every ride. I ride like 8 hours every three weeks so it's not a hassle. I also have two stock filters clean, oiled and on standby if it's a ride over a whole weekend.
post #8 of 12 Old 03-13-2009, 10:27 AM
xx-rated's Avatar
I had a K&N on my Raptor and it did just fine. I checked the inside of my intake regularly and never noticed any dirt. There is a fine line in the amount of oil that you put on the filter as well. I think I probably over oil mine, but better safe than sorry I guess. The one thing I DON'T like about my Velocity is that it does not mount up very tight and you really have to crank down the clamp on it to get it snug.
xx-rated is offline
post #9 of 12 Old 03-13-2009, 10:36 AM Thread Starter
To me, that's the most important thing about quads is how well you maintain them. My 400EX sure could take some abuse though...wow.
post #10 of 12 Old 03-15-2009, 07:00 PM
Which mount kit do you have? Mine came with a collar that slipped in the air box soft pipe to keep it from collapsing and works great. I had seen on a old post somewhere someone had a different setup, they may have revised it after your purchase.
