+3 tb problems - Club700XX - Honda TRX700XX Forum
post #1 of 22 Old 08-01-2011, 06:56 PM Thread Starter
traitor08's Avatar
pissed +3 tb problems
Ok to start here is what I have done. A dynojet licensed tuner tuned my xx, he updated all software and set it up on my laptop, calibrated tps during this process. Checked springpressure on tb and it feels like stock. Checked cable, no hangups and moves freely. To blade out of tb and smoothed edges(was pertty smooth before). Put blade in tb and checked for any sticking, none. Held tb up to light, can barely see sunlight through a couple areas, and I mean barely. Idle screw is barely touching thottle, another 1/4 turn and it wont be.
Now here is theproblem that still exists. Startup rpm is fine, slowly give throttle until maybe 1/4 throttle and let off slowly, rpms hang up and slowly come down but stay above initial startup idle. While cruising, if you shift to 2nd while its hanging it will bring rpms down. Almost to point where all aftermarket parts I got will be sold and I will return to stock and leave it, had tb off 7 or so times today in the 101 deg heat. Getting prety frustrated.
MY RIDES
Amish washing the buggy^^^^
traitor08 is offline
post #2 of 22 Old 08-01-2011, 07:27 PM
It didn't do this at all before the TB? I'd be calling HDD then and asking WTF if that is the case. Do you still have the stock TB to just swap that out to see if that makes a difference?
post #3 of 22 Old 08-01-2011, 07:56 PM Thread Starter
traitor08's Avatar
It didn't do this before tb, I have beenpming him, he has been helpful, at least he has good customer service, that's nice.
MY RIDES
post #4 of 22 Old 08-02-2011, 12:41 AM
Unplug the IAC before you crank it and see if it idles correct when it starts, This will just help narrow down what is causing problem. I had fits with mine doing the same thing.
post #5 of 22 Old 08-02-2011, 01:18 PM
DL700's Avatar
what was the problem, the IAC sticking?
DL700 is offline
post #6 of 22 Old 08-02-2011, 05:46 PM
any efi codes?
EHSRACING is offline
post #7 of 22 Old 08-02-2011, 06:19 PM Thread Starter
traitor08's Avatar
No codes. Its to hot today to mess around with it, heat index of 115.
MY RIDES
post #8 of 22 Old 08-02-2011, 09:17 PM
To be honest, I'm really not sure. I ended up completely tearing down and cleaning the TB. Afterwards it worked fine. KDS had ported it, I won't go much into that...
Traitor, The IAC can be installed incorrectly. Pull it out and make sure it's set the correct way.
post #9 of 22 Old 08-02-2011, 10:16 PM Thread Starter
traitor08's Avatar
Come to think about it, I had to open throttle some to get iac on. That might be my problem. Might need to turn iac a little instead of throttle. Hmmmmm
MY RIDES
post #10 of 22 Old 08-03-2011, 12:10 AM
DL700's Avatar
right,
cant recall if that one was sent out bare or not... the IAC needs to index
DL700 is offline
