50mm Throttle Body Upgrade - Club700XX - Honda TRX700XX Forum
post #1 of 17 Old 08-06-2011, 01:53 PM Thread Starter
This is a stock 09 CRF450 throttle body. The inlet is 53mm and tapers down to 44.5. Monday I'll bring it to the machine and bore the taper to 50mm. I'll keep this thread updated to show the bore and wiring steps for the install.
post #2 of 17 Old 08-06-2011, 04:28 PM
crisco's Avatar
Does that tb measure 50mm at the butterfly or will you have to make a new plate?
2009 Raptor 770R
Monster duals, FCI, PC3, +5 Hotrods, Kenz 105mm cylinder, CP 10.75:1, Barker RHC14 cam, Kibblewhite springs, Trex II port, +3 throttle body, Dynatek programmable, evac valve, 22" Haulers on Douglas wheels
crisco is offline
post #3 of 17 Old 08-06-2011, 07:17 PM Thread Starter
Yes, The butterfly is 50mm. Its just the last inch r so in the rear of the TB that chokes down.
post #4 of 17 Old 08-06-2011, 08:28 PM
VelociRaptor's Avatar
This TB is also used by the LTR drag guys.
Bo White
205-886-7043
VelociRaptor is offline
post #5 of 17 Old 08-06-2011, 10:29 PM
crisco's Avatar
Nice. Odd they taper it so much. Now how do i get one to fit on my Raptor? Its gotta be cheaper than a WK tb...
2009 Raptor 770R
crisco is offline
post #6 of 17 Old 08-06-2011, 10:36 PM Thread Starter
The taper is more than likely the same size as the CRF head port. I've ported my XR head to match the 50mm the TB will be.
I'm 100% sure you could get this on your Raptor cheaper than the WK TB lol!
post #7 of 17 Old 08-07-2011, 01:37 AM
DL700's Avatar
the intake design and inlet going into the throttle body have a great deal of effect on its performance, , even though the tb would work on other models(such as a Rap 700) it wouldnt make near the power
they are tapered for air speed
DL700 is offline
post #8 of 17 Old 08-08-2011, 05:56 PM Thread Starter
Got my piston back today(105mm & 12:1), Increased the valve sizes to 40mm and 33mm, pockets cut .040 deeper and to 23 degrees to match my XR head. Also had antifriction applied and deburred. Tomorrow I'll be sending it out with the crank to be stretched and balanced.
post #9 of 17 Old 08-08-2011, 07:31 PM
whats the yellow button or knob for on the crf throttle body?
post #10 of 17 Old 08-08-2011, 07:43 PM
DL700's Avatar
choke/idle
DL700 is offline
