Web Cam - Club700XX - Honda TRX700XX Forum
post #1 of 84 Old 08-07-2011, 05:19 PM Thread Starter
Web Cam
Ok so here's a question for you motorheads. I want to start going into the motor and do a little work. I know I want to go with an 11:1 compression ratio with an upgraded piston and some headword. But my question is what kind of webb cam and how much head work is too much for trail riding and some drag racing? Obviously upgraded springs and rockers are required im just not sure which cam to get.
post #2 of 84 Old 08-07-2011, 05:56 PM
DL700's Avatar
go with the 290, ill hook u up, it works well even with the lower compression and will make some great Hp with a good head port
DL700 is offline
post #3 of 84 Old 08-07-2011, 06:06 PM Thread Starter
DL could you pm me with some pricing for the porting and cam its gona be a little while before I start this, around a month or two but I want to go ahead and get some info on this.
post #4 of 84 Old 08-07-2011, 06:39 PM
boost addict's Avatar
We have all the pcv maps also
The best in the business
Bo White 205-886-7043
Ed @
Chris & Mike
boost addict is offline
post #5 of 84 Old 08-07-2011, 07:02 PM
08700xx's Avatar
I say you just buy my motor
(DL700)
Jody (Boost Addict)
08700xx is offline
post #6 of 84 Old 08-07-2011, 07:24 PM Thread Starter
Thanks Jody, Im ready for a little more kick under the seat.
Mike if I had 2500 bucks just laying around you could bet I would do it.
post #7 of 84 Old 08-07-2011, 07:28 PM
I am in the same predicament.
I do XC , Ovals and everything inbetween , All need differant motor builds. Eric said he might build something for the trails , I am hoping it will have low end grunt and rev to the moon. It's a big hope but kinda finding worth waiting for.
post #8 of 84 Old 08-07-2011, 07:39 PM
DL700's Avatar
sent a pm///
Baxter, its all about the porting and cam and how well you balance the combination
a Great head can support High rpm power without losing in the low/ mid rpm
DL700 is offline
post #9 of 84 Old 08-07-2011, 07:46 PM
How about if I wanted to run a +3 crank ?
post #10 of 84 Old 08-07-2011, 07:59 PM Thread Starter
Thanks daniel im looking forward to getting it done. If I stay at 11:1 I should be ok on pump gas shouldn't I? Race fuel is hard to find around my area.
